Tablet Acer Iconia A1 830
Habesan
Založen: Jan 12, 2009
PříspěvekZaslal: so únor 10 2018, 22:00    Předmět: Citovat
Udělal jsem malý krůček pro člověka.
Zakoupil jsem konektor AXT440124 a protikus AXT340124 a z jednoho jeho vývodu jsem získal UART signál o rychlosti 921600 baudů za sekundu.
Moc moudrý z toho nejsem.
Pokud by někdo věděl, jak tyhle údaje využít, sem s tím, prosím.
kód:
[PWRAP] pwrap_init_preloader
[PWRAP] pwrap_init
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
[PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
[PMIC_WRAP]wrap_init pass,the return value=0.
pl pmic init start
pl pmic efuse start
pl pmic efuse BUCK trim
[0x1C8]=0xF802
[0x1CA]=0x807F
[0x20E]=0xE0
[0x260]=0xF0
[0x286]=0xF0
pl pmic efuse end
pl pmic en rst [0x126]=0x153
[0x388]=0x3021
[0x38C]=0x0
[0x38E]=0x0
[0x390]=0x0
Leon VRF18_2
[0xE]=0x1
[0x540]=0xA0
Battery exist
[0xE]=0x1
[0x540]=0xA0
pl vm read [0x290]=0x7A
pl vm set [0x290]=0x7C
pl vm check [0x290]=0x7C
pl pmic init done
[PLFM] Init I2C: OK(0)
[PLFM] Init PWRAP: OK(0)
[PLFM] Init PMIC: OK(0)
[PLFM] chip[CA00]
[BLDR] Build Time: 20130904-140051
==== Dump RGU Reg ========
RGU MODE:     71
RGU LENGTH:   FFE0
RGU STA:      80000000
RGU INTERVAL: FFF
RGU SWSYSRST: 0
==== Dump RGU Reg End ====
RGU: g_rgu_satus:1
 mtk_wdt_mode_config  mode value=31, tmp:22000030
PL RGU RST: ??
SW reset with bypass power key flag
Find bypass powerkey flag
 mtk_wdt_mode_config  mode value=70, tmp:22000071
kpd register for pmic set!
mt_usb_calibraion: input_reg = 0x0
mt_usb_calibraion: term_vref = 0x0,  clkref = 0x0, vrt_vref = 0x0,
[RTC] get_frequency_meter: input=0x0, ouput=793
[RTC] External crystal exist
[RTC] bbpu = 0xD, con = 0x426
[RTC] RTC_OSC32CON=0x0
[RTC] irqsta = 0x0, pdn1 = 0x0, pdn2 = 0x201, spar0 = 0x40, spar1 = 0x800
[RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1SW r
[PLFM] WDT reboot bypass power key!
[RTC] rtc_bbpu_power_on done
[SD0] Bus Width: 1
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(193) DS(0) RS(0)
[SD0] Switch to High-Speed mode!
[SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(96) DS(0) RS(0)
[SD0] Bus Width: 8
[SD0] Size: 7508 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15376384), ro(0)
[SD0] Initialized
[SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(0) DS(0) RS(0)
msdc_ett_offline_to_pl: size<2> m_id<0x70>
msdc <0> <HYNIX > <MMC08G>
msdc <1> <xxxxxx> <MMC08G>
msdc failed to find
found:1,i:0
[EMI] DDR3
[EMI] eMMC/NAND ID = 70,1,0,4D,4D,43,30,38,47
[EMI] MDL number = 0
init ddr3 x32
Delay test
rank 0 coarse = 12
rank 0 fine = 48
10:|    0    1    1    1    0    0
opt_dle value:7
in do_sw_tx_dq_dqs_calib new
byte:0, (DQS,DQ)=(8,8)
byte:1, (DQS,DQ)=(8,8)
byte:2, (DQS,DQ)=(8,8)
byte:3, (DQS,DQ)=(8,8)
[EMI] DRAMC calibration passed
[MEM] complex R/W mem test pass
mt8193_init() enter
mt8193_i2c_init() enter
[I2C][PL] [i2c2 set speed] Set sclk to 99 khz (orig: 100 khz)
mt8193_i2c_init() exit
[I2C][PL] [i2c2 write] i2c transaction complate
[I2C][PL] [i2c_read] read byte = 0x82
[I2C][PL] [i2c_read] read byte = 0x1
[I2C][PL] [i2c_read] read byte = 0x0
[I2C][PL] [i2c_read] Done
[I2C][PL] [i2c_read] read byte = 0xFF
[mt8193_i2c_write] Reg[0x1260]=0xFF
set_CKGEN_NFI_PIN_GPIO
mt8193_init() exit
[PLFM] Init Boot Device: OK(0)
============func=load_pt_from_fixed_addr===scan pmt from D00000=====
[SD0] DAT TMO error (0x4000), Left: 2048/2048 bytes, RXFIFO:0
[SD0] Read data error (1)
check card state<4>
find no pt or mpt
============func=load_exist_part_tab===scan pmt from 420400=====
[SD0] DAT TMO error (0x4000), Left: 131072/131072 bytes, RXFIFO:0
check card state<4>
Acer_A1-810__CAPTURE.rar
 Soubor:  Acer_A1-810__CAPTURE.rar
 Velikost:  2.09 kB
 Staženo:  84 krát
(Nemusí mít platnou revizi.)
PříspěvekZaslal: so únor 10 2018, 22:11    Předmět: Citovat
Mas tam nejaku kartu alebo je SD0 nejake integrovane 8GB eMMC? Je to asi vadne.
