Založen: Mar 21, 2006 Příspěvky: 33916 Bydliště: Bratislava
Zaslal: so leden 27 2024, 18:26 Předmět: Acer Aspire 5738
- mrtvy po obliati kavou, POST code D2h
Pred 10 rokmi sa mi do ruk dostal Acer Aspire 5738, ktory bol po obliati kavou mrtvy. Je to Wistron JV50-MV M92 MB (DDR2).
Nasiel som vtedy zhnity RN39. Po oprave sa uz dal zapnut, ale nefungoval. Zisti som, ze nefunguje napajanie VGA, nasiel som este poskodeny R418. Po vymene sa napajanie objavilo, ale notebook nadalej nefungoval - zastavil sa na POST kode D2h. Vratil som to vtedy ako neopravitelne - vadny Radeon.
Niekde sa to 10 rokov valalo a teraz sa mi to vratilo - akurat uz ako dar
Podla schemy som zistil, ze postup nie je uplne kompletny, chyba napr. prepojenie HDA na 1,5V z 3,3V. Autor mal uz Radeon odstraneny, ja este nie. Stale mi to zostavalo na D2 az pokym som neodstranil C213 a C220 - prva PCIe linka Radeonu na chipset. Po tomto sa to rozbehlo a na VGA porte mam obraz. LCD ale nefunguje.
[ 93.707055] [drm] stuck on render ring
[ 93.708402] [drm] GPU HANG: ecode 4:0:0x859ffffb, in X [2424], reason: Ring hung, action: reset
[ 93.708405] [drm] GPU hangs can indicate a bug anywhere in the entire gfx stack, including userspace.
[ 93.708406] [drm] Please file a _new_ bug report on bugs.freedesktop.org against DRI -> DRM/Intel
[ 93.708408] [drm] drm/i915 developers can then reassign to the right component if it's not a kernel issue.
[ 93.708410] [drm] The gpu crash dump is required to analyze gpu hangs, so please always attach it.
[ 93.708412] [drm] GPU crash dump saved to /sys/class/drm/card0/error
[ 93.708414] i915: render error detected, EIR: 0x00000010
[ 93.708417] i915: IPEIR: 0x00000000
[ 93.708419] i915: IPEHR: 0x02000004
[ 93.708421] i915: INSTDONE_0: 0x879fffff
[ 93.708423] i915: INSTDONE_1: 0xbfffffbf
[ 93.708424] i915: INSTDONE_2: 0x00000000
[ 93.708426] i915: INSTDONE_3: 0x00000000
[ 93.708428] i915: INSTPS: 0x8001e025
[ 93.708430] i915: ACTHD: 0x7ff570c4
[ 93.708432] i915: page table error
[ 93.708434] i915: PGTBL_ER: 0x00000001
[ 93.708453] [drm:i915_handle_error [i915]] *ERROR* EIR stuck: 0x00000010, masking
[ 93.708537] drm/i915: Resetting chip after gpu hang
[ 99.703050] [drm] stuck on render ring
[ 99.704409] [drm] GPU HANG: ecode 4:0:0x8d8ffffb, in X [2424], reason: Ring hung, action: reset
[ 99.704479] [drm:i915_gem_init_rings [i915]] *ERROR* gpu hanging too fast, banning!
[ 99.704517] drm/i915: Resetting chip after gpu hang
Toto vyzeralo ako problem s napajanim - skutocne, VCC_GFXCORE bolo len 0,927V. Prepinalo sa to cez Q27 (Q26 je neosadeny), ale bez Radeonu to je vo vzduchu. Spojil som teda D-S Q27, napatie sa zvysilo asi na 1,2V a uz GPU nepada.
Zaslal: ne únor 04 2024, 22:22 Předmět:
LCD ozivene!
BIOSu zjavne chybal RN14, co su pull-upy pre HDMI I2C zbernicu. Asi sa snazil najprv precitat EDID z HDMI, ale skoncilo to chybou (timeoutom) a potom sa uz ani nepokusal inicializovat interne LCD.
Zaslal: pá únor 09 2024, 23:41 Předmět:
Postupne osadzujem chybajuce suciastky, objednane mam G9091-330T11U aj PS8101, takze by mohlo fungovat aj HDMI.
A znovu prestalo fungovat LCD, tentokrat aj s podsvietenim, ale len pri boote. Pri nabehu Linuxu LCD ozilo. V xrandr som videl "fantomovy" VGA monitor.
Osadil som totiz RN30 (4x150R) pre VGA RGB signaly (predtym som ho nemal). Lenze som si nevsimol, ze pri radeone su R569, R570, R572, ktore maju rovnaku funkciu. Tym sa RGB signaly dostali na 50 Ω a to BIOS vyhodnotil ako pripojeny VGA monitor. Po odstraneni R569, R570, R572 uz maju RGB signaly spravnych 75 Ω proti zemi. LCD v BIOSe funguje a VGA monitor sa objavi len ked je skutocne pripojeny.
Zaslal: so březen 09 2024, 17:28 Předmět:
Zistil som, ze nefunguje webkamera. Vidiet ju ako USB zariadenie 0C45:6310 podla standardu UVC, ale nefunguje. Ani v Linuxe, ani vo Windows, ani po vyskusani roznych driverov (ani v XP).
Kamera ma oznacenie Camellia_2G CN0314-SN30-OV03-5.
Je tam SONIX SN9C230CJG a 64KB SPI flash MX25L512, kde zjavne mal byt firmware. Nie je tam ale vobec nic, len same FF
Zaslal: so březen 09 2024, 18:07 Předmět:
Nasiel som subor CCD_Suyin_v5.8.33.501_XPX86.zip.
V nom je adresar Suyin Firmware R02.03.02.
Tam je flashovaci nastroj USBBridgeBurnerAp_v1.1.4.0.exe a adresar s firmware CN0314-SN30-OV03-VA-R02.03.02 (subory 231_OV7725.bin, Acer-20080114D-yellow-1.txt, CN0314-SN30-OV03-VA-R020302_PAR.dat).
Staci spustit nastroj a kliknut na "EZ GO". Po naflashovani vypnut a znovu zapnut notebook. Kamera sa detekuje ako 064e:a103 a funguje
