Eagle - součástky z GME
stepa
Založen: Jan 05, 2007
PříspěvekZaslal: ne únor 17 2008, 15:45    Předmět: Citovat
Dyt to je STROM struktura, uz ti to pisu po nekolikaty 74**245 se da dal rozbalit, ale nato si uz evidentne prisel. Doporucuji ti precist si manual v Eaglu, kdyz ti dela problem najit soucastky...predejdes dalsim omylum. Nick ti ale sedi, v tom mas pravdu Laughing
Brzda
Založen: Jul 06, 2006
PříspěvekZaslal: ne únor 17 2008, 17:35    Předmět: Citovat
Tak este jeden dotaz. Jak mam opravit tyhle chyby:
WARNING: Sheet 1/1: unconnected Pin: R1 1
WARNING: Sheet 1/1: unconnected Pin: R2 1
WARNING: Sheet 1/1: unconnected Pin: R3 1
WARNING: Sheet 1/1: unconnected Pin: R3 2
WARNING: Sheet 1/1: unconnected Pin: R4 1
WARNING: Sheet 1/1: unconnected Pin: R4 2
WARNING: Sheet 1/1: unconnected Pin: R6 2
WARNING: Sheet 1/1: unconnected Pin: R7 1
WARNING: Sheet 1/1: unconnected Pin: R8 1
WARNING: Sheet 1/1: unconnected Pin: LED3 C
WARNING: Sheet 1/1: unconnected Pin: LED4 C
WARNING: Sheet 1/1: unconnected Pin: LED6 C
WARNING: Sheet 1/1: unconnected Pin: LED7 C
ERROR: Sheet 1/1: no SUPPLY for implicit POWER Pin IC1P VCC
WARNING: No Pins on net +5V
WARNING: Only 1 Pin on net GND
WARNING: No Pins on net N$1
WARNING: Only 1 Pin on net N$2
ERROR: Only INPUT Pins on net N$3
WARNING: No Pins on net N$5
WARNING: Only 1 Pin on net N$6
WARNING: Only 1 Pin on net N$7
WARNING: No Pins on net N$8
WARNING: Only 1 Pin on net N$9
WARNING: Only 1 Pin on net N$10
WARNING: Only 1 Pin on net N$11
WARNING: No Pins on net N$12
WARNING: No Pins on net N$13
WARNING: Only 1 Pin on net N$14
WARNING: Only 1 Pin on net N$15
WARNING: No Pins on net N$16
WARNING: No Pins on net N$17
WARNING: No Pins on net N$18
WARNING: Only 1 Pin on net N$19
WARNING: No Pins on net N$22
WARNING: No Pins on net N$23
WARNING: No Pins on net N$25
WARNING: Only 1 Pin on net N$26
WARNING: Sheet 1/1, Net N$5: wire overlaps pin at (-1.025 1.55)
WARNING: Sheet 1/1, Net N$8: wire overlaps pin at (-0.475 1.65)
WARNING: Sheet 1/1, Net N$10: wire overlaps pin at (-0.55 1.75)
WARNING: Sheet 1/1, Net N$12: wire overlaps pin at (-1.025 1.85)
WARNING: Sheet 1/1, Net N$18: wire overlaps pin at (1.375 1.9)
WARNING: Sheet 1/1, Net N$17: wire overlaps pin at (1.375 1.Cool
WARNING: Sheet 1/1, Net N$16: wire overlaps pin at (1.375 1.7)
WARNING: Sheet 1/1, Net N$15: wire overlaps pin at (1.375 1.6)
WARNING: Sheet 1/1, Net N$14: wire overlaps pin at (1.375 1.5)
WARNING: Sheet 1/1, Net N$13: wire overlaps pin at (1.375 1.4)
WARNING: Sheet 1/1, Net N$1: wire overlaps pin at (1.35 1.3)
WARNING: Sheet 1/1, Net N$5: wire overlaps pin at (0.425 1.4)
WARNING: Sheet 1/1, Net N$6: wire overlaps pin at (0.45 1.5)
WARNING: Sheet 1/1, Net N$7: wire overlaps pin at (0.425 1.6)
WARNING: Sheet 1/1, Net N$8: wire overlaps pin at (0.425 1.7)
WARNING: Sheet 1/1, Net N$9: wire overlaps pin at (0.425 1.Cool
WARNING: Sheet 1/1, Net N$12: wire overlaps pin at (0.45 2)
WARNING: Sheet 1/1, Net N$19: wire overlaps pin at (2.05 2.6)
WARNING: Sheet 1/1, Net N$18: wire overlaps pin at (2.025 2.35)
WARNING: Sheet 1/1, Net N$17: wire overlaps pin at (2.025 2.1)
WARNING: Sheet 1/1, Net N$22: wire overlaps pin at (2.4 2.1)
WARNING: Sheet 1/1, Net N$16: wire overlaps pin at (2.025 1.85)
WARNING: Sheet 1/1, Net N$23: wire overlaps pin at (2.375 1.85)
WARNING: Sheet 1/1, Net N$25: wire overlaps pin at (2.375 1.35)
WARNING: Sheet 1/1, Net N$13: wire overlaps pin at (2.025 1.1)
WARNING: Sheet 1/1, Net N$1: wire overlaps pin at (2.05 0.85)
WARNING: Sheet 1/1, Net N$22: wire overlaps pin at (3.5 2.85)
WARNING: Sheet 1/1, Net N$23: wire overlaps pin at (3.8 2.875)
WARNING: Sheet 1/1, Net N$25: wire overlaps pin at (4.4 2.875)
WARNING: Sheet 1/1, Net N$26: wire overlaps pin at (4.7 2.875)
WARNING: Sheet 1/1, Net N$3: wire overlaps pin at (1.6 0.55)
WARNING: Sheet 1/1, Net N$2: wire overlaps pin at (0.1 0.55)
WARNING: Sheet 1/1, Net N$11: wire overlaps pin at (0.05 3.1)
WARNING: Sheet 1/1, Net N$28: wire overlaps pin at (2.9 3.375)
zkousim propojovat soucastky jak chcu, ale u nekterych me to hazi upozorneni a u nekterych dokonce chybu, ale kdyz se podivam na spoj, tak to visualne vypada propojeno
stepa
PříspěvekZaslal: ne únor 17 2008, 17:39    Předmět: Citovat
O prispevek vys jsem ti rikal, at si prectes manual. Evidentne rady neberes v potaz. Nemas tam NIC zapojeneho. Vis vubec jak se spojuji soucastky? Prosvetli si cesty, jak jsou zapojeny, nebo mi posli na mail soubory a ja se na to mrknu.
Brzda
PříspěvekZaslal: ne únor 17 2008, 17:45    Předmět: Citovat
stepa napsal(a):
Tak sem ti to poslal na mail
stepa
PříspěvekZaslal: ne únor 17 2008, 17:55    Předmět: Citovat
To Brzda: mas mail...ale malem jsem vyskocil z okna, kdyz jsem to uvidel. Musel jsem si to zaarchivovat v podobe obrazku Smile .
Brzda
PříspěvekZaslal: ne únor 17 2008, 18:07    Předmět: Citovat
Very Happy to je krasa preci, tohle se me taky objevilo kdyz sem to otevrel znovu. No ja cetl ze se cary delaj pomoci net, tak se omlouvam.
stepa
PříspěvekZaslal: ne únor 17 2008, 18:17    Předmět: Citovat
Jo covece...v tom tranzu z toho schematu jsem psal castecne blbosti Smile , muzes kreslit jak pomoci NET(automaticky dava uzly) i WIRE. Takze si to delal dobre...ale nevim jakto ze se v tom udelal takovej chaos...uz ti to jde? Nevim jak si to moh tak "vykurvit". A pouzivat muzes NET, je to lepsi.
Brzda
PříspěvekZaslal: ne únor 17 2008, 18:19    Předmět: Citovat
no to taky nechapu proc mi to haze tolik chyb, ted sem to predelal pomoci wire a nahazelo me to este vic chyb jak predtim Very Happy. a ono se to tak dodrbe az se to ulozi, do te doby to vypada normalne
Brzda
PříspěvekZaslal: ne únor 17 2008, 18:21    Předmět: Citovat
nemuze to byt treba verzi eaglu? pouzivam 4.16 R2
PaJa-trb
Neregistrovaný
PříspěvekZaslal: ne únor 17 2008, 21:58    Předmět: Citovat
Jak psal stepa, urcite si precti nejakej manual. Eagle se sice oproti ostatnim programum jednoduchej a hodne veci se da vytusit, ale nektery zakladni veci se nejlip naucis z nejakyho manualu (pokud nemas nekoho znalyho po ruce).
Cesty ve schematu se kresli pomoci NET, dulezity je umistovat cestu presne na konec vyvodu soucastky, aby doslo k propojeni.
To poznas tak, ze potom soucastku chytnes MOVE a zkusis ji posunout, cesty by mely drzet a hejbat se s ni, jinak to neni propojeny a hazi to chyby WARNING: Sheet 1/1: unconnected Pin
Pricina problemu muze by i spatne nastaveny rastr GRID, pro navrh schematu je treba dodrzovat nastaveni 2,54mm - v tomto rastru jsou totiz kresleny vsechny (pokud to nekdo nezkopal) schematicke soucastky.
Tvuj "navrh" sem nevidel, takze uzu jen hadat jak to doopravdy je Question
stepa
PříspěvekZaslal: ne únor 17 2008, 22:13    Předmět: Citovat
to Paja: k tomu rastru soucastek...z cadsoftu jsem si stahoval knihovny k integrovanym koncum, ale ten manik co to delal nepouzil "normalni miru" 2,54mm(1inch, nebo 1000mil), ale nejaky uplne trapny rozmer, ktery jsem nebyl ani schopny zadat, tak nezbyvalo nic jineho, nez si ty vyvody upravit(vyslo to casove lepe, nez tvorit novou soucastku). Ale nejaka unifikace by mela byt.
Brzda mel nejakou zkopanou instalaci a mezery ve znalostech, tak jsme to uz vyresili.
pajosek2
Založen: Feb 24, 2007
PříspěvekZaslal: po únor 18 2008, 10:42    Předmět: Citovat
Našli jsme odkaz pro nápovědu k Eaglu,tak jestli to někomu pomůže je to tady www.eagle.cz/tour/tour01.htm
