P: Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H
laser84
Založen: Mar 03, 2024
PříspěvekZaslal: ne březen 03 2024, 11:41    Předmět: P: Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H Citovat
Prodám Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H.
Cena: 700 cz
Možnost osobného predania Praha - Letňany.
Popis EN:
Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H Strong Motor Magnet for Generators Wind Turbine Neodymium NdFeB
Specifications(1"=25.4mm; 1lbs=0.453kg)
Dimensions: OR18.00*IR14.00*45Deg.*20.00mm (+/-0.1mm) (Outer Radius*Inner Radius*Angel*Height)
Material: Neodymium (NdFeB)
Grade: N42H
Maximum Temperature: 120 Degree Celsius (248 deg F)
Coating: Nickel (NiCuNi)
Magnetization: Inside Curve to Outside Curve
1 lot = 4pcs N Pole Outside + 4pcs S Pole Outsid
 Velikost:  183.3 kB
 Zobrazeno:  19 krát
 Velikost:  90.24 kB
 Zobrazeno:  19 krát
 Velikost:  60.52 kB
 Zobrazeno:  20 krát
 Velikost:  281.2 kB
 Zobrazeno:  18 krát
