Lenovo V560 neberie mi žiadnu wifi kartu prečo ?
jano101
Založen: Jun 27, 2007
PříspěvekZaslal: st září 21 2022, 7:38    Předmět: Citovat
tak pri najhoršom tam vrátim zálohu čo mám nie ?
DedVseved
Založen: Jul 01, 2019
PříspěvekZaslal: čt září 22 2022, 10:19    Předmět: Citovat
Mám jinou Atheros/Qualcomm kartu a když jsem se na ni podíval eeprom nástrojem (výpis je z OTP memory), tak ve výpisu žádný Vendor ID není. Otázkou je, kde je a jestli by šel změnit?
kód:
Atheros QCA9882 MAC/BB Rev:2 (SREV: 0x043222ff)
Unable to select GPIO access ops due to unsupported chip
Chip does not support EEPROM
OTP access ops: use QCA988x ops
Try to load data from OTP memory
Found OTP stream (begin: 0x0024, raw data len: 0x02f2 (754), type: 1 (calibration data), version: 1)
Found block at 0: comp=3 ref=3 length=746 major=4 minor=9
Restore eeprom 0: block, reference 3, length 746
Restore at 0: spot=6 offset=6 length=6
Restore at 8: spot=16 offset=4 length=2
Restore at 12: spot=30 offset=12 length=1
Restore at 15: spot=41 offset=10 length=1
Restore at 18: spot=65 offset=23 length=1
Restore at 21: spot=168 offset=102 length=1
Restore at 26: spot=461 offset=37 length=23
Restore at 55: spot=1042 offset=48 length=17
Restore at 74: spot=1067 offset=8 length=14
Restore at 90: spot=1089 offset=8 length=14
Restore at 106: spot=1111 offset=8 length=14
Restore at 122: spot=1133 offset=8 length=14
Restore at 138: spot=1155 offset=8 length=14
Restore at 154: spot=1177 offset=8 length=14
Restore at 170: spot=1199 offset=8 length=14
Restore at 186: spot=1221 offset=8 length=3
Restore at 191: spot=1244 offset=20 length=1
Restore at 194: spot=1257 offset=12 length=1
Restore at 197: spot=1271 offset=13 length=1
Restore at 200: spot=1288 offset=16 length=2
Restore at 204: spot=1294 offset=4 length=2
Restore at 208: spot=1300 offset=4 length=2
Restore at 212: spot=1306 offset=4 length=2
Restore at 216: spot=1312 offset=4 length=239
Restore at 457: spot=1576 offset=25 length=2
Restore at 461: spot=1584 offset=6 length=2
Restore at 465: spot=1589 offset=3 length=15
Restore at 482: spot=1621 offset=17 length=1
Restore at 485: spot=1625 offset=3 length=27
Restore at 514: spot=1669 offset=17 length=13
Restore at 529: spot=1685 offset=3 length=15
Restore at 546: spot=1716 offset=16 length=32
Restore at 580: spot=1764 offset=16 length=32
Restore at 614: spot=1812 offset=16 length=32
Restore at 648: spot=1924 offset=80 length=96
Found OTP stream (begin: 0x0319, raw data len: 0x0029 (41), type: 249 (unknown), version: 3)
Found OTP stream (begin: 0x0345, raw data len: 0x0008 (8), type: 250 (unknown), version: 20)
Found OTP stream (begin: 0x0350, raw data len: 0x0008 (8), type: 250 (unknown), version: 20)
| EEPROM Base Header   |
Length                         : 0x0844
Checksum                       : 0x3CB2
EEP Version                    : 2
Template Version               : 3
MacAddress                     : CC:2D:E0:xx:xx:xx
RegDomain1                     : 0x0000
RegDomain2                     : 0x0000
Allow 5GHz                     : 1
Allow 5GHz HT20/HT40           : 1/1
Allow 5GHz VHT20/VHT40/VHT80   : 1/1/1
Allow 2GHz                     : 0
Allow 2GHz HT20/HT40           : 0/0
Allow 2GHz VHT20/VHT40         : 0/0
Cal Bin Ver                    : 0x0000
TX Mask                        : 0x03
RX Mask                        : 0x03
Tx Gain                        : 0
Rx Gain                        : 0
Power Table Offset             : 0
CCK/OFDM Pwr Delta, dB         : 0
40/20 Pwr Delta, dB            : 0
80/20 Pwr Delta, dB            : 0
Customer Data in hex:
  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00 |................|
  00 00 00 00                                      |....            |
| EEPROM Modal Header  |
                                     5G
Antenna Ctrl Chain 0              :  0x10
Antenna Ctrl Chain 1              :  0x10
Antenna Ctrl Chain 2              :  0x10
Antenna Ctrl Common               :  0x220
Antenna Ctrl Common2              :  0x11111
Antenna Gain                      :  1
NF Thresh                         :  0
| EEPROM Power Info    |
[5 GHz OFDM per-rate target power]
                  Freq, MHz:  5240  5260  5320  5500  5600  5745
             6-24 mbps, dBm:  24.0  24.0  24.0  24.0  24.0  24.0
               36 mbps, dBm:  23.0  23.0  23.0  23.0  23.0  23.0
               48 mbps, dBm:  22.0  22.0  22.0  22.0  22.0  22.0
               54 mbps, dBm:  20.0  21.0  21.0  21.0  21.0  21.0
[5 GHz HT20/VHT20 per-rate target power]
     HT MCS VHT MCS | Freq, MHz:  5240  5260  5320  5500  5600  5745
          0       0,        dBm:  23.0  23.0  23.0  23.0  23.0  23.0
        1-2     1-2,        dBm:  23.0  23.0  23.0  23.0  23.0  23.0
        3-4     3-4,        dBm:  23.0  23.0  23.0  23.0  23.0  23.0
          5       5,        dBm:  21.0  21.0  21.0  21.0  21.0  21.0
          6       6,        dBm:  20.0  21.0  21.0  21.0  21.0  21.0
          7       7,        dBm:  19.0  20.0  20.0  20.0  20.0  20.0
                  8,        dBm:  17.0  18.0  18.0  18.0  18.0  18.0
                  9,        dBm:  15.0  16.0  16.0  16.0  16.0  16.0
          8      10,        dBm:  23.0  23.0  23.0  23.0  23.0  23.0
       9-10   11-12,        dBm:  23.0  23.0  23.0  23.0  23.0  23.0
      11-12   13-14,        dBm:  23.0  23.0  23.0  23.0  23.0  23.0
         13      15,        dBm:  21.0  21.0  21.0  21.0  21.0  21.0
         14      16,        dBm:  21.0  21.0  21.0  21.0  21.0  21.0
         15      17,        dBm:  19.0  20.0  20.0  20.0  20.0  20.0
                 18,        dBm:  17.0  18.0  18.0  18.0  18.0  18.0
                 19,        dBm:  15.0  16.0  16.0  16.0  16.0  16.0
[5 GHz HT40/VHT40 per-rate target power]
[5 GHz VHT80 per-rate target power]
[5 GHz CTL data]
  FCC 5GHz OFDM:
           Edges, MHz:  5180  [5260   5280   5500   5700] [5720   5745   5825]
      MaxTxPower, dBm:  30.0   30.0   30.0   30.0   30.0   30.0   30.0   30.0
  FCC 5GHz HT20:
  FCC 5GHz HT40:
           Edges, MHz:  5190  [5270   5310]  5510  [5670   5710] [5755   5795]
  FCC 5GHz VHT20:
           Edges, MHz: [5210   5290] [5530   5610] [5690   5775]
  MKK 5GHz OFDM:
           Edges, MHz:  5180  [5240   5260   5320] [5500   5520   5680] [5700
  MKK 5GHz HT20:
  MKK 5GHz HT40:
           Edges, MHz: [5190   5230] [5270   5310] [5510   5550   5630] [5670
  MKK 5GHz VHT20:
  ETSI 5GHz OFDM:
  ETSI 5GHz HT20:
  ETSI 5GHz HT40:
  ETSI 5GHz VHT20:
