Založen: Aug 02, 2009 Příspěvky: 1321 Bydliště: Praha
Zaslal: so leden 02 2021, 22:32 Předmět:
No takze kdyz ty casti cos precetl z disku nahrajes do flash, tak by to melo jit?
U me neprekvapive prohozeni tech 2 desek na 2TB discich vedlo k tomu, ze nefunguje ani jeden, normalne se roztoci a identifikujou, nijak necvakaj, ale linux hlasi nake serious erory, ze jako z nej nejde cist. Tu flashku sem zkusil pridat do sveho SPIPGM, tak to du zkusit sfouknout a precist. BTW ta moje je na 1.8V, level konverter uz sem si delal driv.
Založen: Mar 21, 2006 Příspěvky: 33945 Bydliště: Bratislava
Zaslal: ne leden 03 2021, 12:14 Předmět:
WD Marvel vie dokonca sam vygenerovat ROM zo servisnej oblasti, nemusel som sa s tym srat rucne. Po naflashovani disk funguje a vyzera byt zdravy
kód:
smartctl 6.6 2017-11-05 r4594 [i686-linux-5.7.0-0.bpo.2-686] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Caviar Blue Serial ATA
Device Model: WDC WD2500AAJS-75M0A0
Serial Number: WD-xxxxxxxxxxxx
LU WWN Device Id: 0 000000 000000000
Firmware Version: 05.04E05
User Capacity: 250,000,000,000 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.5, 3.0 Gb/s
Local Time is: Sun Jan 3 12:05:55 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 5460) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 67) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3037) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Nechapem, co mu vlastne stalo. Moduly v ROM aj v servisnej oblasti mali spravny checksum (aj ked obsah dvoch spominanych bol rozdielny) - takze nemohlo ist o nahodne poskodenie.
Podozrive je, ze povodny ROM modul 0D obsahoval nazov disku a verziu firmware 02.03E02. V cinskej ROM ani v module zo servisnej oblasti nazov ani verzia FW nie je. Teraz to ukazuje FW 05.04E05.
Zaslal: ne leden 03 2021, 14:24 Předmět:
Ked uz mam funkcnu ROM, pohral som sa s doskami s CPU s internou flash (88i8846) - 2060-701590-000 REV A a 2060-771590-001 REV P2.
Po naflashovani spravnej ROM s nimi disk funguje, takze sa daju pouzit ako nahrada dosky 2060-771590-001 REV A s 88i8846E a externou flash.
Postup: samotnu dosku zapojit na SATA a napajanie, pockat niekolko minut, kym vzda pokusy o inicializaciu (zmizne BSY flag) a nasledne zapisat programom WD Marvel.
Zaslal: ne leden 03 2021, 18:25 Předmět:
Tak to gratulace...
A na Seagate disky by naky tooly nebyly?
Z tech 2TB disku sem vydumpoval flashe (1MB) a porovnal, je tam celkem 54525 diferenci ruzne rozesetych v oblastech 30008-3FFFF, 7002E-7F209, ACE02-FFFC0, na konci ma jedna pamet blok FF zatim co druha tam ma naka data, takze to nevypada na par kalibracnich dat, mozna se tam ukladaji cele SMART logy...?
Citelnych retezcu v tom moc neni, asi nejzajimavejsi:
kód:
Polar 8051 Calibration timed out; drive will hang
Wait for Polar 8051 idle timed out; drive will hang
Polar 8051 Calibration Failed, controls =
Ale mam tu jiny problem, nenadale mi prestal fungovat jiny disk Seagate 200GB SATA ST3200826AS, ktery se uplne prestal detekovat. Jeste pred tydnem sem na nej instaloval Win na naky SW, dival sem se na SMART a zadne relocated ani pending sektory nemel. Ted sem ho znovu vytah, pripojil, primo SATA kabelem k desce a nic, zadna detekce. Disk se roztoci a je slyset, ze kazdych cca 8s kratce tukne hlavou. Zkousel sem ho dat do mrazaku, ale nepomohlo. Na te elektronice je taky naka fleska SST25VF. Si rikam, ze kdyz je typ disku, ktery se vypisuje pri detekci, ulozeny v ni, tak by to mohl bejt taky nakej problem s fleskou, ze se jebl naky bit a vubec nenastartuje FW. Zkusim ji vycitat pri ruznych napetich, jesi teda se neceho doberu...
Zaslal: ne leden 03 2021, 21:55 Předmět:
Nove zistenie: pri flashovani ROM cez WD Marvel nepouzivat 256KB subor (image celej flash), ale len 192KB. Pri flashnuti 256KB suboru ostane ROM prazdna...
Pomocou self-scanu v STComTools som rozchodil par diskov vhodnych predtym akurat na vyhodenie. Na niektorych to skoncilo s chybou - tie som rozobral a vyhodil. Myslim, ze podobny postup pouziva Seagate aj pri reklamaciach...co prejde, oznacia ako "Certified Refurbished".
Založen: Apr 02, 2011 Příspěvky: 17796 Bydliště: Nový Bydžov
Zaslal: ne leden 03 2021, 22:12 Předmět:
Teď nám prosím ještě doplň, jestli jsi to dělal kvůli záchraně dat, za kterou někdo dobře zaplatil a nebo jen tak z plezíru aby sis dokázal, že to zvládneš opravit ať to stojí, co to stojí. _________________ Jirka
Zaslal: ne leden 03 2021, 23:57 Předmět:
rnbw napsal(a):
Zkusil sem precist tu SPI flash SST25VF512 (64kB) a az do 1.7V davala konzistentni obsah, pro jistotu sem ji este smazal a znova zapsal, ale zadna zmena.
Ted sem se pripojil seriovym kabelem, chytlo se to na 9600bd, 3,3V.
kód:
4096k x 16 buffer detected
TONKA - 1_Disk M-27 03-30-05 11:42
Head Mask FFFF - Switch to full int.
Spin Ready
3.03 06-21-05 17:16
Zkoustim ST Repair Tool 2013-5-10 ktery ma nejmin cinskych tlacitek, tuknul sem na "Start SF", ted to ruzne hrabe a toci motorem, nemam to zrovna pripojene SATA kabelem, tak mi to zaclo hazet "SATA interrupt nor processed!"
Založen: May 13, 2009 Příspěvky: 4992 Bydliště: BA-Petržalka :(
Zaslal: po leden 04 2021, 1:16 Předmět:
Tak ono tie utility od výrobcov sú celkom silný nástroj. Vedia rozosrať, ale aj opraviť disk. Práve sa tu hrám s diskom od Samsungu, starý 40 GB. Objavil som že tu mám Ultimate Boot CD, a na ňom kopa utilít pre harddisky. Skúsil som jednu pre staré Samsungy. Samozrejme som si nepozrel či je disk podporovaný, veď načo, že (odkazovalo to na internet)... Spustili sa rôzne testy, asi šesť ich prebehlo v poriadku, potom sa z disku ozval divný zvuk chŕŕŕ cvak cvak chŕŕŕŕŕ, na obrazovke blikali posledné dva testy, a reprák v PC pípal prerušovane, pritom kontrolka disku už nesvietila, ďalej sa nič nedialo a nereagovalo, len to pípanie. Takže Ctrl+Alt+Del. Disk stíchol. Ako ho očuchával BIOS, zasa tie divné zvuky, dlho to skúšalo, a BIOS napísal chybu disku. Skúsil som novšiu utilitu pre Samsungy z toho istého CD, tam pekne našlo disk, všetky testy prebehli bezchybne, a disk zasa funguje ako predtým. Ufff. _________________ Silou vybrať peniaze od ľudí a následne za ne spraviť niečo proti ľuďom, s čím nesúhlasia, to je civilizácia?! Tento systém je chorý a vedie do záhuby.
Zaslal: po leden 04 2021, 13:53 Předmět:
Tak errory to psalo i pri pokusu o formatovani ty SMART oblasti, nakonec sem neopatrnou manipulaci dojebal elektroniku, odesel tam 1 nakej miniaturni spinak, mozna motor driver a neco dalsiho, uz nejede ani seriak, tak na to asi seru. Teoreticky tu mam este o neco novejsi baracudu 7200.9, ktera ma mechnicky kompatabilni elektroniku, FW TONKA2, ta z disku pochopitelne nenacte zadny modul a je jen v F modu. Primo pro ten samy disk neni k dispozici FW pro nahrani pres tool, jen pro nejake jine kapacity, to je otazka jesi by i FW pro jiny disk, kdyby se ho nejak podarilo nahrat na servisni stopy, rozpoznal spravne datovou oblast...
Jinak v tom STComToolu nejak nefungovalo zadny ukladani ani nahravani pameti ci stop, nejak to rozjebalo UART, vypsalo naky rozsypany caje a zanechalo terminal ve stavu ze neprijimal/nevysilal zadne znaky, bylo treba to pozavirat (nekdy natvrdo sestrelit proces) a odevrit znova. zrejme se to nak snazilo prepnout na vyssi baudy ale nepovedlo se.
Zaslal: út květen 24 2022, 16:14 Předmět:
Mam tu jeden polomrtvy HDD Seagate ST2000DM001 s FW CC24. Chova se tak, ze pri detekci BIOSu visi asi pul minuty, pak se detekuje, ale pri pokusech o cteni system zas vytuhne v nakem timeoutu. Nejde precist ani SMART. Obcas se ale podari precist MBR nebo par sektoru ze zacatku, kde je videt NTFS. Shodou okolnosti mam ST2000DM001 s FW CC25, ale deska elektroniky je dost odlisna uz od pohledu tvarem a layoutem. Nicmene jsem zkusil elektroniky pro srandu prohodit a pak nejede ani jeden disk. Kdyz navic prohodim i SPI Flash, tak uz se nerozjede ani motor, takze ten FW proste neni schopen jet s jinym HW. Ale spis to bude asi naka mech. zavada uvnitr. Nejaky napad co s tim jeste vyzkouset nez to vratim s tim, at si to dotycny donese do DataHelpu?
Zaslal: čt leden 05 2023, 22:25 Předmět:
Tak tu mam jeden zrejme skleroticky SSD ADATA SX300 64GB, ktery jsem pred casem zachranil ze srotu. NA prvni pohled se SSD tvaril OK, precetl sem z nej i vsechna data po puvodnim majiteli, akorat se parkrat stalo, ze se disk pri cteni nejak zadrhnul a musel jsem ho odpojit a pripojit, pak zas ta data sla cist. SSD sem mel pripojeny pres USB, takze sem to prikladal za vinu spis nespolehlivymu prevodniku...
Jenze pozdeji jsem zistil, ze jsou s nim problemy i pri pripojeni na onboard SATA radic. SSD sem kompletne vymazal pres ATA Secure Erase (utilitou vyrobce ADATA SSD Toolbox), cimz se behem par s vsechny sektory vynulovaly. V tomto stavu se SSD chovalo OK, pri cteni dosahoval vysoke rychlosti a pri cteni vsech sektoru nebyla zadna chyba. Jenze jakmile sem SSD rozdelil a nahral na nej OS a dalsi programy, tak nastaly problemy. Kdykoliv jsem zacal vice cist nez jen sem tam jednotlivy soubor, tak se SSD zaseknul, HDD LED zustala trvale svitit a uz jsem z nej nic neprecet. Az po tvrdem resetu zas nabehl a mohl sem neco malo precist. SSD obsahuje legendarni srackoradic SandForce 2281 (ktery provadi runtime kompresi dat), tak jsem zkusil aktualizovat FW z 5.0.2 na posledni 5.8.2, vymazal ho a znovu nahral data - zapis byl bez problemu, ale nasledne cteni opet s dlouhatanskymi timeouty, takze novy FW ani full erase to neresi. SSD proste postupne presel do faze WOM (write-only memory . Tak nevim, jestli ty flash cipy uz sou tak v riti nebo je to jiny FW problem? Potodykam, ze ve SMARTu zadne chyby nejsou a zivotnost disk ukazuje na 100%. Take ty puvodni data, co na nem byly, pochazely nekdy z roku 2013 a pak asi SSD lezel nekde v supliku, presto slo vsechno (s par zadrhelama) precist. A to sem cet, ze u nakych SSD bez napajeni se muzou data vyparit velmi brzy.
Jako posledni moznost by se dala vyzkouset tovarni reinicializace leaknutym softwarem Genesis primo od vyrobce prepnutim do recovery rezimu pomoci jumperu, ale ten postup je docela komplikovany, vyzaduje instalaci urcite verzi Fedory v kere ten SW bezi... ale spis myslim, ze to uz bude proste naka degradace tech flash cipu, ze by to stejne nikam nevedlo....
Strana 4 z 5
