Modul SIM800 řízený ESP32 CAM
markoni
Založen: Oct 30, 2006
PříspěvekZaslal: pá srpen 27 2021, 13:15    Předmět: Modul SIM800 řízený ESP32 CAM Citovat
Mám takový projekt který v modulu kamery ESP32 CAM udělá obrázek a pošle ho pomocí modulu SIM800l na FTP server
Zdroják
kód:
#include "esp_camera.h"
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
camera_config_t config;
void setup() {
  Serial.begin(9600);
  initCamera();
  takePhoto();
  ATInternet();
void loop() {
  //takePhoto();
  //delay(10000);
void initCamera() {
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_XGA;//FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
  } else {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
void takePhoto() {
 byte dat=0;
  camera_fb_t * fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  Serial.print("Velikost obrazu: ");
  Serial.print(fb->len);
  Serial.print(" B,");
  Serial.print((fb->len)/1024);
  Serial.println(" KB");
  Serial.print((fb->len) % 1024);
  //Serial.print("0x");
  /*for(int i=0;i<fb->len;i++)
     Serial.print(fb->buf[i], HEX);*/
Serial.println("");
//  dat = HEX(fb->buf);
  //Serial.write(fb->buf,fb->len);
  if(!fb) {
    Serial.println("Camera capture failed");
   while(fb->len){
//      dat=fb->buf,fb->len;
    //Serial.print(fb->buf,fb->len);
    return;
   * Free buffer cam
  esp_camera_fb_return(fb);
void ATInternet(){
  int poz=0;
  int dopocet=1024;
  String mesage="";
  delay(10000);
  Serial.print("AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r");
  Serial.flush();
  delay(1000);
  while(Serial.available()){
    mesage=mesage+Serial.read();
  Serial.print("AT+SAPBR=3,1,\"APN\",\"internet\"\r");
  Serial.flush();
  delay(1000);
 Serial.print("AT+SAPBR=1,1\r");
 Serial.flush();
 delay(1000);
 Serial.print("AT+SAPBR=2,1\r");
 Serial.flush();
 delay(1000);
Serial.print("AT+FTPCID=1\r");
Serial.flush();
 delay(1000);
  Serial.print("AT+FTPSERV=\"***********\"\r");
  Serial.flush();
 delay(1000);
Serial.print("AT+FTPUN=\"*********\"\r");
Serial.flush();
  delay(1000);
Serial.print("AT+FTPPW=\"********\"\r");
Serial.flush();
delay(1000);
Serial.print("AT+FTPPUTPATH=\"/**************/\"\r");
Serial.flush();
delay(1000);
Serial.print("AT+FTPPUTNAME=\"picture.jpg\"\r");
Serial.flush();
delay(1000);
  Serial.print("AT+FTPPUT=1\r");
Serial.flush();
delay(3000);
  int c=(fb->len)/1024;
for(int l=0;l<=c;l++){
Serial.print("AT+FTPPUT=2,1024\r");
Serial.flush();
delay(3000);
  for(int i=0;i<=1024;i++)
     Serial.print(fb->buf[poz]);
     poz++;
  // put your setup code here, to run once:
delay(3000);
int z=(fb->len)%1024;
Serial.print("AT+FTPPUT=2,");
Serial.print(z);
Serial.print("\r");
Serial.flush();
 for(int i=0;i<=z;i++){
     poz++;
Serial.print("AT+FTPPUT=2,0\r");
Serial.flush();
někde mám chybu ale nevím kde ? o chybě kde tam chybí
AT+FTPTYPE=I
vím a doplním ale to pořád nevysvětluje že na FTP serveru jsou bloky ne malé stejných dat a to je špatně .Další chyba je že některé ty pakety se nepřenesou ale to je asi problém mobilního signálu to bych zatím neřešil .
Další věc ta kamera někdy alokuje větší prostor pro bufer na obrázek a a ten modul ESP32 CAM se resetuje tu část kódu taky jsem nedělal já taky by se někdo s této komunity mohl podívat jestli tam někde není chyba ? já vím že chci od vás mnoho ale nemohu si pomoc Confused
díky moc za pomoc
edit přidávám ještě výpis na seriového monitoru to není ten samý seasion
soubor na ftp.txt
 Soubor:  soubor na ftp.txt
 Velikost:  49.11 kB
 Staženo:  1146 krát
seriový monitor.txt
 Soubor:  seriový monitor.txt
 Velikost:  30.76 kB
 Staženo:  1176 krát
