Neupgradovatelny FW Zyxel P-660HW-T3 v2 V3.40(BEI.0)
PříspěvekZaslal: út říjen 20 2020, 8:59    Předmět: Neupgradovatelny FW Zyxel P-660HW-T3 v2 V3.40(BEI.0) Citovat
Objavil som odlozeny ADSL router Zyxel P-660HW-T3 v2. Zdalo sa, ze funguje - ale pre istotu som premeral ESR elytov. Par sa mi zdalo podozrivych, tak som ich vybral - a mimo obvodu boli uplne v prdeli - nakoniec som vymenil vsetky znacky JH.
Dalsi krok - upgrade firmware. Bol tam V3.40(BEI.0), ale Zyxel ma na webe V3.40(ANR.5). Uz som tusil, ze s tym bude problem. Samozrejme, ze upgrade nefungoval a na webe som nasiel viackrat potvrdene, ze to nejde.
Nejde to ani cez seriovu konzolu:
kód:
Bootbase Version: V1.04 | 6/28/2006 10:10:34
RAM: Size = 16384 Kbytes
DRAM POST: Testing: 16384K
OK
FLASH: AMD 16M *1
ZyNOS Version: V3.40(BEI.0)  | 12/25/2007  14:41:37
Press any key to enter debug mode within 3 seconds.
Enter Debug Mode
ATHE
======= Debug Command Listing =======
AT            just answer OK
ATHE          print help
ATBAx         change baudrate. 1:38.4k, 2:19.2k, 3:9.6k 4:57.6k 5:115.2k
ATENx,(y)     set BootExtension Debug Flag (y=password)
ATSE          show the seed of password generator
ATTI(h,m,s)   change system time to hour:min:sec or show current time
ATDA(y,m,d)   change system date to year/month/day or show current date
ATDS          dump RAS stack
ATDT          dump Boot Module Common Area
ATDUx,y       dump memory contents from address x for length y
ATRBx         display the  8-bit value of address x
ATRWx         display the 16-bit value of address x
ATRLx         display the 32-bit value of address x
ATGO(x)       run program at addr x or boot router
ATGR          boot router
ATGT          run Hardware Test Program
ATRTw,x,y(,z) RAM test level w, from address x to y (z iterations)
ATSH          dump manufacturer related data in ROM
ATTD          download router configuration to PC via XMODEM
ATUR          upload router firmware to flash ROM
ATLC          upload router configuration file to flash ROM
< press any key to continue >
ATXSx         xmodem select: x=0: CRC mode(default); x=1: checksum mode
ATSR          system reboot
ATSP          send packet
ATMU          print Multiboot client version
ATEB            prit ExpressBoot client version
OK
ATSH
ZyNOS Version          : V3.40(BEI.0)  | 12/25/2007  14:41:37
Bootbase Version       : V1.04 | 6/28/2006 10:10:34
Vendor Name            : ZyXEL Communications Corp.
Product Model          : P-660HW-T3 v2
ZyNOS ROM address      : bfc10000
System Type            : 7
MAC Address            : xxxxxxxxxxxx
Default Country Code   : F6
Boot Module Debug Flag : 00
RomFile Version        : 68
RomFile Checksum       : 74fe
ZyNOS Checksum         : 11a5
Core Checksum          : 870f
SNMP MIB level & OID   : 060102030405060708091011121314151617181920
Main Feature Bits      : C0
Other Feature Bits     :
          01 5B 00 00 01 00 00 00-00 00 00 00 00 00 00 00
          00 00 00 00 00 00 00 00-02 41 13 00 00 00
OK
ATBA5
Now, console speed will be changed to 115200 bps
OK
ATXS1
OK
ATUR
Starting XMODEM upload (checksum mode)....
UUU
Total  1896960 bytes received.
Wrong product firmware!!
Please upgrade the newest firmware version!!
ERROR
Po chvili hladania som zistil, ze prve dva bajty "Other Feature Bits" su identifikator modelu a treba ich zmenit. Lenze ake tam maju byt?
Nasiel som pekny commit v OpenWrt, ktory pridava podporu pre zariadenia Zyxel:
https://gitlab.nic.cz/turris/openwrt/-/commit/42b664a30a7481f05ecdd909baa4f0032e5e8e3d
Odtial som zistil, ze treba vo firmware najst retazec "Model 1". Za nim nasleduje cislo (decimalne), v pripade V3.40(ANR.x) "15770", co je 0x3D9A. Takze prve dva bajty "Other Feature Bits" treba nastavit na 0x9A, 0x3D (lebo je to v big endiane):
kód:
Enter Debug Mode
ATEN1,C43C2958
OK
ATCL
OK
ATCB
OK
ATBU
System Type            : 7
MAC Address            : 0023F8A7A70A
OK
ATDU8001F468,20
8001F468: 01 5B 00 00 01 00 00 00-00 00 00 00 00 00 00 00   .[..............
8001F478: 00 00 00 00 00 00 00 00-02 41 13 00 00 00 C0 00   .........A......
OK
ATWB8001F468,9A
OK
ATWB8001F469,3D
OK
ATBU
System Type            : 7
          9A 3D 00 00 01 00 00 00-00 00 00 00 00 00 00 00
OK
ATBT1
OK
ATSB
OK
ATSH
System Type            : 7
OK
8001F468 je adresa v bufferi v RAM. V inej verzii Bootbase moze byt ina! Nasiel som ju dumpovanim adresneho priestoru cez XMODEM (prikaz ATDO).
A uz to fici Very Happy
kód:
ATUR
U
Erasing..............................
OK
System Reboot...
Console speed will be changed to 9600 bps
OK
FLASH: AMD 16M *1
ZyNOS Version: V3.40(ANR.5) | 12/31/2009  14:33:00
Enter Debug Mode
ATSH
ZyNOS Version          : V3.40(ANR.5) | 12/31/2009  14:33:00
System Type            : 7
MAC Quantity           : 1
ZyNOS Checksum         : 9848
Core Checksum          : f55b
OK
