Bateria Sanyo GRAPE32 (a ine s bq8030)
PříspěvekZaslal: po leden 16 2017, 22:21    Předmět: Bateria Sanyo GRAPE32 (a ine s bq8030) Citovat
Mam tu notebook Acer s vadnou bateriou Sanyo GRAPE32 s bq8030DBT. Rozobral som ju, pretoze sa nedala nabijat ani vybijat. Clanky boli rozidene a podvybite (dve dvojice mali 2,7 V, tretia 3 V), zrovnal som ich lab. zdrojom.
Nasiel som paradny web k bateriam Sanyo s tymto bq8030:
http://www.karosium.com/2016/08/hacking-bq8030-with-sanyo-firmware.html
Ten clovek urobil paradny open-source SW na komunikaciu s bateriami a k tomu este firmware pre FX2LP modul, ktory sa da zohnat lacno na eBay (a dokonca som ho uz mal, pretoze sa da pouzit ako logicky analyzer prakticky zadarmo):
http://www.karosium.com/p/smbusb.html
Bateria GRAPE32 ma hned pri - pole SCL a vedla SDA. Tieto tri piny staci prepojit s FX2LP a komunikacia bezi (ziadne napajanie netreba).
kód:
$ ./smbusb_sbsreport
SMBusb Firmware Version: 1.0.1
Manufacturer Name:          SANYO
Device Name:                GRAPE32
Device Chemistry:           LION
Serial Number:              6467
Manufacture Date:           2008.02.05
Manufacturer Access:        0f08
Remaining Capacity Alarm:   400 mAh(/10mWh)
Remaining Time Alarm:       10 min
Battery Mode:               0000
At Rate:                    0 mAh(/10mWh)
At Rate Time To Full:       65535 min
At Rate Time To Empty:      65535 min
At Rate OK:                 65535
Temperature:                26.15 degC
Voltage:                    10470 mV
Current:                    0 mA
Average Current:            0 mA
Max Error:                  0 %
Relative State Of Charge    0 %
Absolute State Of Charge    0 %
Remaining Capacity:         0 mAh(/10mWh)
Full Charge Capacity:       1015 mAh(/10mWh)
Run Time To Empty:          0 min
Average Time To Empty:      0 min
Average Time To Full:       65535 min
Charging Current:           0 mA
Charging Voltage:           0 mV
Cycle Count:                211
Manufacturer Data:          fffffff7
Metoda na pristup k bootloaderu, uvedena v clanku, funguje aj s bateriou GRAPE32. smbusb_bq8030flasher tiez funguje, stiahol som firmware aj EEPROM Smile
kód:
$ ./smbusb_comm -a 16 -c 71 -w 0214
$ ./smbusb_comm -a 16 -c 73 -r 2
01f9
$ ./smbusb_comm -a 16 -c 71 -w fe07
$ ./smbusb_comm -a 16 -c 70 -w 0517
$ ./smbusb_bq8030flasher -p prg.bin -e eep.bin
PEC is ENABLED
TI Boot ROM version 3.1
Reading program flash
Done!
Reading eeprom(data) flash
Done!
Takze uz len najst, co tam upravit, aby to zacalo nabijat.
