Zaslal: po prosinec 14 2015, 11:24 Předmět: PIC-Problem s nastavenim portov.
Zdravim,
Snazim sa naprogramovat casovac,ktory bude ovladat bodovu zvaracku.
Pracujem v MPLABe.
Procesor PIC16F628A.
Mam problem s nastavenim portov A ako vstupnych a to konkretne A0, A1, A2, A3.Planujem na nich napojit pull-upp rezistory.
Program ako je napisany v code funguje korektne pokial sa nepokusim spominane porty v programe pouzit.
V datasheete sa uvadza:
2: On Reset, the TRISA register is set to all
inputs. The digital inputs (RA<3:0>) are
disabled and the comparator inputs are
forced to ground to reduce current
consumption.
Cize pravdepodobnym dovodom preco program blbne je to ze su porty vypnute,popr. to ze su povolene komparatory.
Na a neviem vycitat z datasheetu ako porty zapnut, popr.deaktivovat komparatory, alebo co vlastne robit
kód:
; Projekt: Bodovacka
LIST p=16F628A ;type of processor
#INCLUDE <P16F628A.INC> ; definitoins
Založen: Dec 26, 2004 Příspěvky: 1462 Bydliště: Košice - okolie
Zaslal: po prosinec 14 2015, 11:44 Předmět:
Mas to priamo v katalogu
kód:
CLRF PORTA ;Initialize PORTA by
;setting
;output data latches
MOVLW 0x07 ;Turn comparators off and
MOVWF CMCON ;enable pins for I/O
;functions
BCF STATUS, RP1
BSF STATUS, RP0 ;Select Bank1
MOVLW 0x1F ;Value used to initialize
;data direction
MOVWF TRISA ;Set RA<4:0> as inputs
;TRISA<5> always
;read as ‘1’.
;TRISA<7:6>
;depend on oscillator
;mode
