// Feel Free to edit these variables ///////////////////////////
String xLabel = "Analogue Inputs";
String yLabel = "Voltage (V)";
String Heading = "The Graph Sketch";
String URL = "01/02/2010";
float Vcc = 5.0; // the measured voltage of your usb
int NumOfVertDivisions=5; // dark gray
int NumOfVertSubDivisions=10; // light gray
int NumOfBars=6; // you can choose the number of bars, but it can cause issues
// since you should change what the arduino sends
// if these are changed, background image has problems
// a plain background solves the problem
int ScreenWidth = 600, ScreenHeight=400;
// Serial port stuff ///////////////////////
import processing.serial.*;
Serial myPort;
boolean firstContact = false;
int[] serialInArray = new int[6];
int serialCount = 0;
int LeftMargin=100;
int RightMArgin=80;
int TextGap=50;
int GraphYposition=80;
float BarPercent = 0.4;
int value;
PFont font;
PImage bg;
int temp;
float yRatio = 0.58;
int BarGap, BarWidth, DivisounsWidth;
int[] bars = new int[NumOfBars];
void setup(){
// bg = loadImage("BG.jpg");
/// NB SETTINGS ////////////////////////////////////////////////////////
myPort = new Serial(this, Serial.list()[0], 9600);
size(ScreenWidth,ScreenHeight);
font = createFont("Arial",12);
textAlign(CENTER);
textFont(font);
void draw(){
// background(bg); // My one used a background image, I've
background(250); // commented it out and put a plain colour
// Headings(); // Displays bar width, Bar gap or any variable.
Axis();
Labels();
PrintBars();
// Send Recieve data //
void serialEvent(Serial myPort) {
// read a byte from the serial port:
int inByte = myPort.read();
if (firstContact == false) {
if (inByte == 'A') {
myPort.clear(); // clear the serial port buffer
firstContact = true; // you've had first contact from the microcontroller
myPort.write('A'); // ask for more
else {
// Add the latest byte from the serial port to array:
serialInArray[serialCount] = inByte;
serialCount++;
// If we have 6 bytes:
if (serialCount > 5 ) {
for (int x=0;x<6;x++){
bars[x] = int (yRatio*(ScreenHeight)*(serialInArray[x]/256.0));
// Send a capital A to request new sensor readings:
myPort.write('A');
// Reset serialCount:
serialCount = 0;
//Sending 8 bit reading (256) so analogue
//reading can be sent in 1 serial.write() instead
int Analogue0 = 0; // first analog sensor
int Analogue1 = 0; // second analog sensor
int Analogue2 = 0; // digital sensor
int Analogue3 = 0; // second analog sensor
int Analogue4 = 0; // second analog sensor
int Analogue5 = 0; // second analog sensor
int inByte = 0; // incoming serial byte // incoming serial serial.write() instead
void setup()
// start serial port at 9600 bps:
Serial.begin(9600);
establishContact(); // send a serial.write() instead to establish contact until Processing responds
void loop()
// if we get a valid serial.write() instead, read analog ins:
if (Serial.available() > 0) {
// get incoming byte:
inByte = Serial.read();
// read first analog input, divide by 4 to make the range 0-255:
Analogue0 = analogRead(0)/4;
// delay 10ms to let the ADC recover:
delay(10);
// read second analog input, divide by 4 to make the range 0-255:
Analogue1 = analogRead(1)/4;
// read switch, multiply by 155 and add 100
// so that you're sending 100 or 255:
delay(10);
Analogue2 = analogRead(2)/4;
delay(10);
Analogue3 = analogRead(3)/4;
delay(10);
Analogue4 = analogRead(4)/4;
delay(10);
Analogue5 = analogRead(5)/4;
delay(10);
// send sensor values: 0451 je to dost pošahaný, takže bacha
Serial.write(Analogue0 );
Serial.write(Analogue1 );
Serial.write(Analogue2 );
Serial.write(Analogue3 );
Serial.write(Analogue4 );
Serial.write(Analogue5 );
Graf se ovšem nemění... četl jsem kód, a podle mě to funguje tak, že nejdříve po sériové lince putuje testovací signál, znak "A", a pak by měly putovat hodnoty z analogového senzoru. Ovšem, když použiji serial monitor v Arduino IDE, vidím jen samá áčka, donekonečna.
HW problémem není, zkoušel jsem použít jednoduší kombinaci programů pro A a P, a fungovalo to bez problémů.
Jako testovací zapojením mám otočný potenciometr v režimu odporového děliče (pravá noha 5V, prostřední A0 a levá na GND). Používám NANO.
