Založen: Nov 07, 2005 Příspěvky: 1520 Bydliště: Studénka
Zaslal: st prosinec 01 2010, 12:38 Předmět: TV SONY (např.KDL40EX705) a spotřeba ve Stby=podvod, vše OK
V popisech TV SONY čtu, že spotřeba této řady EDGE LED TV je v provozu kolem 100 W a ve standby 0,20 W, např. zde je uvedeno:
http://www.sony.cz/product/t32-ex-series/kdl-40ex705#pageType=TechnicalSpecs
Příkon – pohotovostní režim (W).........0,20
Spotřeba energie (režim Shop) (W).....107
Spotřeba energie (režim Home) (W)......79
Tyto parametry vypadaly lákavě, než jsem si našel u SONY následující vysvětlení (promiňte, že zde používám původní text v angličtině):
1. dotaz:
Why can't the Standby indicator be switched off?
Solution description
1. The Standby indicator can not be turned off by the Power key.
2. The power consumption of the set is as low as for the past models. Power consumption: 29W
3. This brings better usability. Even when the TV is turned off by the Power key, later it is possible to turn on the set by the remote. But if the indicator is off, it will be hard to know if the set is in a status that can receive the remote conrol. So, for this model the indicator is kept on.
2. dotaz:
How can the Power key and the Energy Saving Switch be used properly?
The Power key on the TV has the same function as the one on the remote. Press to turn the TV on or off (standby). You can use the Power key on the remote as well.
The Energy Saving Switch is to reduce power consumption, which connects/disconnects the TV from/to the mains. Press to switch the TV on or off. When the Energy Saving Switch is switched off, you will not be able to perform such functions as saving clock settings, downloading EPGs, or updating software.
If the TV is in standby mode when the Energy Saving Switch is switched off, switching it on puts the TV back into standby mode. In this case, press the Power key on the TV or on the remote after switching the Energy Saving Switch on to turn the TV on.
Jestli to dobře chápu, když vypnu tento SONY TV dálkovým ovládačem do Standby, baští si "neuvěřitelných 29W". Pokud pak na boku TV použiji vypínač "ENERGY SAVING SWITCH", (což je téměř ekvivalentní úplnému odpojení od sítě), klesne spotřeba na těch 0,20 W, ale v tom stavu nelze TV zapnout dálkovým ovládačem.
Pokud to tak skutečně je, je to pěkný podvod na zákaznících, protože v uživatelském manuálu k TV není o tom ani zmínka.
Zajímalo by mne, jakou spotřebu ve stavu Standby mají jiné značkové TV, např. Panasonic, LG, Samsung, Sharp apod.
Založen: Jul 02, 2005 Příspěvky: 184 Bydliště: slovensko
Zaslal: st prosinec 01 2010, 13:15 Předmět:
Dobrý deň,
neverte všetkému čo si prečítate v manuáloch, lebo tie manuály či sú na Samsungoch,LG,popr iné značky sú robené alebo preložené ľudmi ktorý
jasne nerozumejú týmto veciam,pokiaľ by to bolo tak ako tvrdíte vy tak taký TVP by bol nepredajný. V solidných kamenných obchodoch Vám ten konkrétny model vysvetlia, predvedú aj s meraním el.energie,robia to aj v NAY.
Moje osobné skuśenosti sú pri meraní tohto modelu v standby0,15W,
a spotreba pri režime štandard 25-30W to sú moje osobné skúsenosti s týmto modelom, u ostatných modelov s LED podsvitením 40palcov uhlopriečka to bolo skoro na vlas podobné
Založen: Jun 13, 2004 Příspěvky: 5666 Bydliště: Břeclavsko
Zaslal: st prosinec 01 2010, 17:20 Předmět:
Hlavně na měření spotřeby nepoužívej ty šmejdový watmetry za tři stovky. Ty ti klidně udělají z bezdrátového zvonku co je napájený ze sítě přes kondík 30ti watovýho žrouta. Ty jsou tak leda měření spotřeby obyč. vařiče nebo žárovky.
Zaslal: po prosinec 13 2010, 10:13 Předmět:
Spotřeba ve Standby je v pořádku, jen ten anglický výklad je trochu zavádějící.
V menu TV lze nastavit skutečně dva režimy Standby, jeden s rychlým náběhem a větší spotřebou a druhý úplný s delším náběhem a nízkou spotřebou.
Toto nastavení má řadu časových variant podle potřeb uživatele.
