Mám jinou Atheros/Qualcomm kartu a když jsem se na ni podíval eeprom nástrojem (výpis je z OTP memory), tak ve výpisu žádný Vendor ID není. Otázkou je, kde je a jestli by šel změnit?
kód:
Atheros QCA9882 MAC/BB Rev:2 (SREV: 0x043222ff)
Unable to select GPIO access ops due to unsupported chip
Chip does not support EEPROM
OTP access ops: use QCA988x ops
Try to load data from OTP memory
Found OTP stream (begin: 0x0024, raw data len: 0x02f2 (754), type: 1 (calibration data), version: 1)
Found block at 0: comp=3 ref=3 length=746 major=4 minor=9
Restore eeprom 0: block, reference 3, length 746
Restore at 0: spot=6 offset=6 length=6
Restore at 8: spot=16 offset=4 length=2
Restore at 12: spot=30 offset=12 length=1
Restore at 15: spot=41 offset=10 length=1
Restore at 18: spot=65 offset=23 length=1
Restore at 21: spot=168 offset=102 length=1
Restore at 26: spot=461 offset=37 length=23
Restore at 55: spot=1042 offset=48 length=17
Restore at 74: spot=1067 offset=8 length=14
Restore at 90: spot=1089 offset=8 length=14
Restore at 106: spot=1111 offset=8 length=14
Restore at 122: spot=1133 offset=8 length=14
Restore at 138: spot=1155 offset=8 length=14
Restore at 154: spot=1177 offset=8 length=14
Restore at 170: spot=1199 offset=8 length=14
Restore at 186: spot=1221 offset=8 length=3
Restore at 191: spot=1244 offset=20 length=1
Restore at 194: spot=1257 offset=12 length=1
Restore at 197: spot=1271 offset=13 length=1
Restore at 200: spot=1288 offset=16 length=2
Restore at 204: spot=1294 offset=4 length=2
Restore at 208: spot=1300 offset=4 length=2
Restore at 212: spot=1306 offset=4 length=2
Restore at 216: spot=1312 offset=4 length=239
Restore at 457: spot=1576 offset=25 length=2
Restore at 461: spot=1584 offset=6 length=2
Restore at 465: spot=1589 offset=3 length=15
Restore at 482: spot=1621 offset=17 length=1
Restore at 485: spot=1625 offset=3 length=27
Restore at 514: spot=1669 offset=17 length=13
Restore at 529: spot=1685 offset=3 length=15
Restore at 546: spot=1716 offset=16 length=32
Restore at 580: spot=1764 offset=16 length=32
Restore at 614: spot=1812 offset=16 length=32
Restore at 648: spot=1924 offset=80 length=96
Found OTP stream (begin: 0x0319, raw data len: 0x0029 (41), type: 249 (unknown), version: 3)
Found OTP stream (begin: 0x0345, raw data len: 0x0008 (8), type: 250 (unknown), version: 20)
Found OTP stream (begin: 0x0350, raw data len: 0x0008 (8), type: 250 (unknown), version: 20)
| EEPROM Base Header |
Length : 0x0844
Checksum : 0x3CB2
EEP Version : 2
Template Version : 3
MacAddress : CC:2D:E0:xx:xx:xx
RegDomain1 : 0x0000
RegDomain2 : 0x0000
Allow 5GHz : 1
Allow 5GHz HT20/HT40 : 1/1
Allow 5GHz VHT20/VHT40/VHT80 : 1/1/1
Allow 2GHz : 0
Allow 2GHz HT20/HT40 : 0/0
Allow 2GHz VHT20/VHT40 : 0/0
Cal Bin Ver : 0x0000
TX Mask : 0x03
RX Mask : 0x03
Tx Gain : 0
Rx Gain : 0
Power Table Offset : 0
CCK/OFDM Pwr Delta, dB : 0
40/20 Pwr Delta, dB : 0
80/20 Pwr Delta, dB : 0
