PIC MPLABX XC pokusy
delis
Založen: Jul 10, 2005
PříspěvekZaslal: pá únor 10 2017, 21:51    Předmět: PIC MPLABX XC pokusy Citovat
Zdravím pánové,
zkouším proramovat PIC 16F1824, experimentuji s Timerem 2, když ho zapnu T2CONbits.TMR2ON = 1 v inicializaci, pak pracuje, když nechám jeho aktivaci do nekonečné smyčky, pak se nerozběhne, lze takto timer zapnout?
Jinak níže přiložený program:
Led je rozsvicovaná v zavislosti na osvětlení fotorezistoru, druhá led na LATC0 bliká cca dle inkrementace timeru.
Diky.
kód:
#include <xc.h>
/***** CONFIGURATION *****/
//  ext reset, internal oscillator (no clock out), 4xPLL off
#pragma config MCLRE = ON, FOSC = INTOSC, CLKOUTEN = OFF, PLLEN = OFF
//  no watchdog timer, brownout resets enabled, low brownout voltage
#pragma config WDTE = OFF, BOREN = ON, BORV = LO
//  no power-up timer, no failsafe clock monitor, two-speed start-up disabled
#pragma config PWRTE = OFF, FCMEN = OFF, IESO = OFF
//  no code or data protect, no write protection
#pragma config CP = OFF, CPD = OFF, WRT = OFF
//  stack resets on, high-voltage programming
#pragma config STVREN = ON, LVP = OFF
// Pin assignments
#define LED     LATCbits.LATC1      // indicator LED
/***** MAIN PROGRAM *****/
void main() {
    /*** Initialisation ***/
    // configure ports
    TRISC = 0b111100; // configure RC1 RC0 as an output
    //  (RA1/C12IN0- is an input)
    ANSELAbits.ANSA1 = 1; // select analog mode for RA1/C12IN0-
    // configure fixed voltage reference
    FVRCONbits.FVREN = 1; // FVR enabled
    FVRCONbits.CDAFVR = 0b01; // Comp+DAC output is 2x (= 1.024 V)
    //  -> output 2.048 V to comparators
    // configure comparator 2
    CM2CON0bits.C2ON = 1; // comparator enabled
    CM2CON0bits.C2OE = 0; // external output disabled
    CM2CON0bits.C2POL = 0; // output not inverted
    CM2CON0bits.C2SP = 1; // normal power mode
    CM2CON0bits.C2HYS = 1; // hysteresis enabled
    CM2CON0bits.C2SYNC = 0; // asynchronous output
    CM2CON1bits.C2PCH = 0b10; // + in = fixed voltage ref
    CM2CON1bits.C2NCH = 0b00; // - in = C12IN0- pin
    //  -> C2OUT = 1 if C12IN0- < 2.048 V
    //timer 2
    T2CONbits.T2CKPS = 0b11; // 1:64
    T2CONbits.T2OUTPS = 0b0111; // 1:8
    //  -> increment TMR2 cca 2s
    PIR1bits.TMR2IF = 0; //  clear overflow flag
        //T2CONbits.TMR2ON = 1; // stop Timer
   /*** Main loop ***/
    for (;;) {
        // continually display comparator output
        LED = CM2CON0bits.C2OUT;
        T2CONbits.TMR2ON = 1; // start Timer
        if (PIR1bits.TMR2IF == 1) {
            LATCbits.LATC0 = ~LATCbits.LATC0;
PříspěvekZaslal: pá únor 10 2017, 22:18    Předmět: Citovat
PIC neznám, ale co vlastně zapnutí timeru dělá? Není jeho součástí inicializace? Tedy se snažíš timer plnou rychlostí MCU neustále dokola inicializovat, čili timer běžet nemůže? Co se stane, když běžící timer přeteče, zastaví se? Pokud ano, tak timer spusť před vstupem do smyčky a ve smyčce pak testuj přetečení, tak, jak to máš, ale timer znovu spusť jenom, pokud došlo k přetečení.
delis
PříspěvekZaslal: pá únor 10 2017, 22:57    Předmět: Citovat
Jo jo, bude to tou inicializací plnou rychlostí, když do hlavního cyklu doplním podmínku, že se ON timer nastaví jen jednou, tak se rozběhne
kód:
for (;;) {
        if (T2CONbits.TMR2ON == 0)
Na tuto vlastnost jsem narazil vlastně tak, že jsem chtěl programem nastavit děličku, rychlejší a pomaleší blikání a nechodilo to, tak jsem zkoušel timer zastavovat a zapínat. Musím to nastavování registrů ošetřit tak, aby to vždy proběhlo jen jednou.
Díky
