Založen: Aug 04, 2009 Příspěvky: 1301 Bydliště: okres Písek
Zaslal: pá říjen 06 2023, 21:27 Předmět:
Záleží, jak kdo chápe ten zápis. Nic matematického (historicky) v tom nic nevidím.
Takže např. 2 na druhou plus 2(hexa) plus faktoriál 1 AND 5 (špatně). Nebo třeba 2×(ASCII 64) plus (ASCII 36)×2 plus ASCII (33) minus (ASCII 56)×5 (špatně).
Jak to vlastně registračníci myslí, to by mě taky zajímalo.
Je to tak důmyslné, aby se ani umělá inteligence nedokázala registrovat.
kód:
BARD:
The expression "2@ + $2 + ! - &5 how much?" does not have a unique answer, as the meaning of the symbols @, !, and & is ambiguous.
One possible interpretation is that the symbols @, !, and & are used to represent mathematical operations. In this case, the expression could be evaluated as follows:
Another possible interpretation is that the symbols @, !, and & are used to represent other types of operations, such as programming operations or string operations. In this case, the value of the expression would depend on the specific meaning of the symbols in the context in which the expression is used.
For example, in a programming language, the symbol @ might be used to represent the dereference operator, the symbol ! might be used to represent the negation operator, and the symbol & might be used to represent the bitwise AND operator. In this case, the value of the expression would depend on the data types and values of the operands.
kód:
hey bard, I think you are onto something, but I think for !, @, #, $, you should substitute the numbers corresponding to these keys
View other drafts
kód:
BARD:
Ah, I see. In that case, the expression "2@ + $2 + ! - &5 how much?" could be evaluated as follows:
Prostě ty znaky jsou tam jen "pro zmatení nepřítele".
ale potom je to 2+2-5 a to je -1, co je zle.
ani ked ! beries ako negaciu, tak to nijak nesedi.
2+2+5 = 9
jedine, zeby ten vykricnik znamenal negovanie predtym: -4+5
alebo to cele nedava zmysel a pocitaju s tym, ze tam ludia skusia dat nejake cislo, a budu skusat od 1. _________________ No vidis, a tak si sa bal
