Založen: Mar 21, 2006 Příspěvky: 33754 Bydliště: Bratislava
Zaslal: so prosinec 28 2019, 15:26 Předmět: Upgrade stareho bluetooth adapteru MSI BToes MS-6970
Zo suflika bol vytiahnuty stary USB bluetooth adapter MSI BToes MS-6970 s cielom pouzit ho k bluetooth sluchadlam.
Obaval som sa, ze nepojde v novsich Windows a ze bude problem so zvukom (podpora A2DP?). Vo Windows 7 funguje ako "Generic bluetooth adapter", ale druha obava sa naplnila - funguje len mono zvuk.
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Deducing device DFU version from functional descriptor length
Found Runtime: [0db0:6970] ver=0525, devnum=7, cfg=1, intf=2, path="3-2", alt=0, name="UNKNOWN", serial="UNKNOWN"
Vytiahneme firmware (funguje az na druhy raz):
kód:
# dfu-util -U backup.bin
dfu-util 0.9
Opening DFU capable USB device...
ID 0db0:6970
Run-time device DFU version 0100
Claiming USB DFU Runtime Interface...
Determining device status: state = appIDLE, status = 0
Device really in Runtime Mode, send DFU detach request...
Resetting USB...
dfu-util: Lost device after RESET?
dfu-util 0.9
ID 0db0:ffff
Determining device status: state = dfuIDLE, status = 0
dfu-util: WARNING: Runtime device already in DFU state ?!?
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
dfuIDLE, continuing
DFU mode device DFU version 0100
Device returned transfer size 1023
Copying data from DFU device to PC
Upload [=========================] 100% 354826 bytes
Upload done.
Potrebuje ale 8Mbit flash. Takze zozhnat SST39VF800A v TFBGA a vymenit. Nasledne cez SPI interface toho CSR naflashovat bootloader - to by som mal asi vyskusat ako prve. Otazne je, ci nahodou pre 8Mbit nie je potrebny iny bootloader... Potom by sa mal dat naflashovat firmware 1586 s podporou BT 1.2.
