Zaslal: po duben 06 2026, 9:59 Předmět: Hledám, kdo má programátor na MC64HC11
Konkrétně mi jde o čip MC68HCP11A1P PDIP-48 (48-pin plastic dual in-line package).
Pokusit se vyčíst obsah 512 bytes of EEPROM
Zálohovat a zapsat do EEPROM "nového" čipu. Děkuji
kód:
AI:How to read out EEPROM of this chip and store it to another one.
Thought for 7s
Reading out and copying the 512-byte internal EEPROM from a Motorola MC68HCP11A1P (or similar 68HC11A1 variant) to another identical chip requires a specialized approach. The EEPROM is internal to the microcontroller, so you cannot access it like a standalone memory chip. You need either a dedicated programmer or bootstrap-mode software tools.Recommended Methods
The most reliable and common ways are:
1. Use a dedicated HC11 Programmer (easiest and safest)
◦ Tools like the ETL HC11 Programmer, CarProg (with A10 cable), or similar professional MC68HC11 programmers support direct read/program of the internal EEPROM.
◦ These often work in In-Circuit (ICP) or On-Board (socket/adapter) mode.
◦ In On-Board mode, you insert the chip into an adapter for safer reading, especially if the chip might be security-protected.
2. Bootstrap Mode + PC Software (DIY-friendly)
◦ Put the chip in bootstrap mode (MODA = MODB = 0 during reset).
◦ Use software like PCbug11, or custom routines from Motorola app notes (e.g., AN1010) to dump the EEPROM via the SCI serial port.
Warning: Many 68HC11 variants have a security bit in the CONFIG register. Reading a secured chip in normal bootstrap mode often erases the EEPROM/RAM for protection. Use a tool that supports secured chips or On-Board programming to avoid data loss. Always read and save the dump first.
Založen: Apr 02, 2011 Příspěvky: 20601 Bydliště: Nový Bydžov
Zaslal: po duben 06 2026, 10:38 Předmět:
Můj Xeltec Superpro L+ sice H11 umí, má ZIF 48 ale potřebuje redukci PEP11, protože signály na ZIF48 Xeltecu jsou některý jinde než na H11. No a sehnat tu redukci je asi ještě větší problém, než vlastní programátor. Aspoň tyhle kecy to napsalo, když jsem v programu H11 zvolil. _________________ Jirka
@samec USB převodník na TTL a hardwerové zapojení MC68HC11 je jen část příběhu.
Dále je třeba sw na straně PC a "uploudnout" firmware do RAM uC.
Tohle jsou úlohy, které já v této chvíli nedokážu udělat...
Poptávám nejlépe někdo, kdo tento uC zná, ví co dělá a má na to nástroje.
Mám možnost Beeprog2, jinak jsem to předtím dělal přes bootloader , ale pokud je uzamčen obvod, tak to pak jednině někdo s Xprog , který by to měl umět
Založen: Jun 30, 2024 Příspěvky: 269 Bydliště: střední Čechy u Koněpruských jeskyní
Zaslal: út květen 12 2026, 17:52 Předmět:
bdn napsal(a):
Konkrétně mi jde o čip MC68HCP11A1P PDIP-48.
Poslal jsem ti v poledne SZ. Díval jsem se , zda to náš programátor umí.
Ano, umí 68HC11.. ALE, ten obvod má security bit , čili může být, že čtení EEPROM bude bloknuté. Dá se to obejít, protože ta EEPROM není moc velká , akorát že to nejde dělat programátorem, ale musí se to udělat extra přípravkem a zabere to dost času. _________________ S časem se vše zhoršuje (zákon prof. Parkinsona).
