Rozchodil som laserovy fax s tlaciarnou Canon FAX-L140 - sice z kontajnera, ale je ako novy - gumove casti v podavacoch nemaju ziadne opotrebovanie. Problem je, ze na to asi neexistuje ziadny driver Driver pre L160/L140 na to nepasuje, pretoze tento ma ine ID (L140/L130)... A vsetko, co som nasiel pre "L140/L130" bol len malware (sracky typu "driver updater").
lsusb:
kód:
# lsusb -v -s 2:2
Bus 002 Device 002: ID 04a9:26b6 Canon, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x04a9 Canon, Inc.
idProduct 0x26b6
bcdDevice 1.00
iManufacturer 1 Canon Inc.
iProduct 2 L140/L130
iSerial 3 xxxxxxxxxxxxx
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 2mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 7 Printer
bInterfaceSubClass 1 Printer
bInterfaceProtocol 2 Bidirectional
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Podla tohoto by to malo podporovat format LIPSLX. Ten sa ale podla vsetkeho vyskytuje iba v japonsku Driver pre L160 pouziva UFR II... Tento fax je pritom normalny europsky model, v menu je aj cestina.
Založen: Mar 21, 2006 Příspěvky: 34073 Bydliště: Bratislava
Zaslal: po duben 23 2018, 22:35 Předmět:
Takze oficialne FAX-L140 nepodporuje tlac a nema USB konektor. Preto na webe Canonu ziadny driver nie je. Otazne je, preto tam ten konektor teda osadili?
Podla zoznamu dielov ma L140 inu riadiacu dosku ako L160.
Ja mam: FM3-5453-000 (SCNT BOARD ASS'Y EUR2/EUR3.)
L160 by mala mat: FK2-6328-000 (SCNT BOARD ASS'Y L160 TW/US/CA/AU/ASIA/KR/EUR1/EUR2/EUR3),
pripadne FM3-5432-000 (SCNT BOARD ASS'Y L160 CN)
Dosky budu asi rovnake s malymi rozdielmi - na procesore je nalepka, kde su vsetky varianty a jedna z nich je oznacena. Otazne je, ci je rozdiel len vo firmware alebo je tam aj napr. vacsia RAM.
