Zahadny Canon FAX-L140 - neexistuje driver?
PříspěvekZaslal: po duben 23 2018, 21:04    Předmět: Zahadny Canon FAX-L140 - neexistuje driver? Citovat
Rozchodil som laserovy fax s tlaciarnou Canon FAX-L140 - sice z kontajnera, ale je ako novy - gumove casti v podavacoch nemaju ziadne opotrebovanie. Problem je, ze na to asi neexistuje ziadny driver Shocked Driver pre L160/L140 na to nepasuje, pretoze tento ma ine ID (L140/L130)... A vsetko, co som nasiel pre "L140/L130" bol len malware (sracky typu "driver updater").
lsusb:
kód:
# lsusb -v -s 2:2
Bus 002 Device 002: ID 04a9:26b6 Canon, Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x04a9 Canon, Inc.
  idProduct          0x26b6
  bcdDevice            1.00
  iManufacturer           1 Canon Inc.
  iProduct                2 L140/L130
  iSerial                 3 xxxxxxxxxxxxx
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         7 Printer
      bInterfaceSubClass      1 Printer
      bInterfaceProtocol      2 Bidirectional
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Podla tohoto by to malo podporovat format LIPSLX. Ten sa ale podla vsetkeho vyskytuje iba v japonsku Shocked Driver pre L160 pouziva UFR II... Tento fax je pritom normalny europsky model, v menu je aj cestina.
kód:
$ cat /sys/devices/pci0000:00/0000:00:1e.0/0000:01:05.2/usb2/2-3/2-3:1.0/ieee1284_id
MFG:Canon;MDL:L140/L130 Series;CMD:LIPSLX,CPCA;CLS:PRINTER;DES:Canon L140/L130 Series;
PříspěvekZaslal: po duben 23 2018, 22:35    Předmět: Citovat
Takze oficialne FAX-L140 nepodporuje tlac a nema USB konektor. Preto na webe Canonu ziadny driver nie je. Otazne je, preto tam ten konektor teda osadili? Shocked
Podla zoznamu dielov ma L140 inu riadiacu dosku ako L160.
Ja mam: FM3-5453-000 (SCNT BOARD ASS'Y EUR2/EUR3.)
L160 by mala mat: FK2-6328-000 (SCNT BOARD ASS'Y L160 TW/US/CA/AU/ASIA/KR/EUR1/EUR2/EUR3),
pripadne FM3-5432-000 (SCNT BOARD ASS'Y L160 CN)
Dosky budu asi rovnake s malymi rozdielmi - na procesore je nalepka, kde su vsetky varianty a jedna z nich je oznacena. Otazne je, ci je rozdiel len vo firmware alebo je tam aj napr. vacsia RAM.
