Spravne suciastky
Karya
Založen: Feb 18, 2009
PříspěvekZaslal: pá duben 21 2017, 19:45    Předmět: Spravne suciastky Citovat
Caute
Nenasiel by sa tu niekdo ochotny mi ppomoct so spravnim vyberom suciastok pre riadiacu jednotku schodou. Schema a plosak som nasiel na nete. Nerad by som nakupil nespravne suciastky. Vopred dakujem
kód:
Partlist
Exported from schody.sch at 21.4.2017 21:12:42
EAGLE Version 7.2.0 Copyright (c) 1988-2014 CadSoft
Assembly variant:
Part     Value            Device             Package            Library               Sheet
C1       22pF             C-EU025-024X044    C025-024X044       rcl                   1
C2       22pF             C-EU025-024X044    C025-024X044       rcl                   1
C3       100nF            C-EU025-024X044    C025-024X044       rcl                   1
C4       100nF            C-EU025-024X044    C025-024X044       rcl                   1
C5       1000uF           CPOL-EUE1.8-4      E1,8-4             rcl                   1
C6       1000uF           CPOL-EUE1.8-4      E1,8-4             rcl                   1
C7       100nF            C-EU025-024X044    C025-024X044       rcl                   1
C8       100nF            C-EU025-024X044    C025-024X044       rcl                   1
C9       200nF            C-EU025-024X044    C025-024X044       rcl                   1
C10      200nF            C-EU025-024X044    C025-024X044       rcl                   1
C14      200nF            C-EU025-024X044    C025-024X044       rcl                   1
C15      200nF            C-EU025-024X044    C025-024X044       rcl                   1
IC1      TLC5940          IC-PACKAGE_DIL28-3 IC-PACKAGE_DIL28-3 TLC5940               1
IC2      ATMEGA328P-PUPTH ATMEGA328P-PUPTH   DIL28-3            Restful_Network_relay 1
IC3      7805TV           7805TV             TO220V             linear                1
IC4      TLC5940          IC-PACKAGE_DIL28-3 IC-PACKAGE_DIL28-3 TLC5940               1
Q1       IRF512           IRF512             TO220BV            transistor-power      1
Q2       IRF512           IRF512             TO220BV            transistor-power      1
Q3       IRF512           IRF512             TO220BV            transistor-power      1
Q4       IRF512           IRF512             TO220BV            transistor-power      1
Q5       IRF512           IRF512             TO220BV            transistor-power      1
Q6       IRF512           IRF512             TO220BV            transistor-power      1
Q7       IRF512           IRF512             TO220BV            transistor-power      1
Q8       IRF512           IRF512             TO220BV            transistor-power      1
Q9       16MHz            CRYSTALHC49U-V     HC49U-V            crystal               1
Q10      IRF512           IRF512             TO220BV            transistor-power      1
Q11      IRF512           IRF512             TO220BV            transistor-power      1
Q12      IRF512           IRF512             TO220BV            transistor-power      1
Q13      IRF512           IRF512             TO220BV            transistor-power      1
Q14      IRF512           IRF512             TO220BV            transistor-power      1
Q15      IRF512           IRF512             TO220BV            transistor-power      1
Q16      IRF512           IRF512             TO220BV            transistor-power      1
Q17      IRF512           IRF512             TO220BV            transistor-power      1
Q18      IRF512           IRF512             TO220BV            transistor-power      1
Q19      IRF512           IRF512             TO220BV            transistor-power      1
Q20      IRF512           IRF512             TO220BV            transistor-power      1
Q21      IRF512           IRF512             TO220BV            transistor-power      1
Q22      IRF512           IRF512             TO220BV            transistor-power      1
Q23      IRF512           IRF512             TO220BV            transistor-power      1
Q24      IRF512           IRF512             TO220BV            transistor-power      1
Q26      IRF512           IRF512             TO220BV            transistor-power      1
R12      10k              R-EU_0204/7        0204/7             rcl                   1
R13      10k              R-EU_0204/7        0204/7             rcl                   1
R30      10k              R-EU_0204/7        0204/7             rcl                   1
R31      10k              R-EU_0204/7        0204/7             rcl                   1
R32      10k              R-EU_0204/7        0204/7             rcl                   1
R33      10k              R-EU_0204/7        0204/7             rcl                   1
RN1      8x10k            G08R               SIL9               resistor-sil          1
RN2      8x10k            G08R               SIL9               resistor-sil          1
RN3      8x10k            G08R               SIL9               resistor-sil          1
X1                        AK300/2            AK300/2            con-ptr500            1
X2                        AK300/2            AK300/2            con-ptr500            1
X3                        AK300/2            AK300/2            con-ptr500            1
X4                        AK300/2            AK300/2            con-ptr500            1
X5                        AK300/2            AK300/2            con-ptr500            1
X6                        AK300/2            AK300/2            con-ptr500            1
X7                        AK300/2            AK300/2            con-ptr500            1
X8                        AK300/2            AK300/2            con-ptr500            1
X9                        AK300/2            AK300/2            con-ptr500            1
X10                       AK300/2            AK300/2            con-ptr500            1
X11                       AK300/2            AK300/2            con-ptr500            1
X12                       AK300/3            AK300/3            con-ptr500            1
X13                       AK300/2            AK300/2            con-ptr500            1
X14                       AK300/2            AK300/2            con-ptr500            1
X15                       AK300/2            AK300/2            con-ptr500            1
X16                       AK300/2            AK300/2            con-ptr500            1
X17                       AK300/3            AK300/3            con-ptr500            1
X18                       AK300/3            AK300/3            con-ptr500            1
X19                       AK300/3            AK300/3            con-ptr500            1
X20                       AK300/3            AK300/3            con-ptr500            1
X21                       AK300/3            AK300/3            con-ptr500            1
X28                       AK300/2            AK300/2            con-ptr500            1
Naposledy upravil Karya dne pá duben 21 2017, 20:13, celkově upraveno 1 krát.
Cowley
Založen: Feb 04, 2005
PříspěvekZaslal: pá duben 21 2017, 19:57    Předmět: Citovat
No a to schema?
A program do mikroprocesoru si udelas sam?
EDIT: uz je tam Smile
EDIT2: v seznamu je vse krome D1-3.
Naposledy upravil Cowley dne pá duben 21 2017, 20:24, celkově upraveno 1 krát.
Karya
PříspěvekZaslal: pá duben 21 2017, 20:20    Předmět: Citovat
Nasiel k scheme
Karya
PříspěvekZaslal: pá duben 21 2017, 20:29    Předmět: Citovat
cau Cowley
Ja by som skvor potreboval linky napr na gme.cz. bojim sa ze zle nieco kupim.
Cowley
PříspěvekZaslal: pá duben 21 2017, 20:41    Předmět: Citovat
Tak to se omlouvam, ale z mobilu to dnes fakt nedam Smile
Jen vim, ze TLC5940 v GME nevedou...
Karya
PříspěvekZaslal: pá duben 21 2017, 20:45    Předmět: Citovat
To som objednal z ebay. Dik
PříspěvekZaslal: so duben 22 2017, 0:44    Předmět: Citovat
Možná takhle, ale ať to po mně někdo zkontroluje (aneb plzeň mi chutnala):
C1, C2: https://www.gme.cz/ck-22p-100v-npo-rm2-54-5-hitano
C3, C4: https://www.gme.cz/ck-100n-50v-x7r-rm2-54-10-hitano
C5, C6: https://www.gme.cz/ce-1000u-25v-hit-ecr-10x21-rm5-bulk
C7, C8: https://www.gme.cz/ck-100n-50v-x7r-rm2-54-10-hitano
C9, C10, C14, C15: https://www.gme.cz/ck-220n-63v-z5u-20-rm5-08-hitano
IC1: ebay
IC2: https://www.gme.cz/atmega328p-pu-sdip28-atmel (snad tento, někdo doplní. Ale hlavně musí být naprogramovaný).
IC3: https://www.gme.cz/stabilizator-pevneho-napeti-st-microelectronics-thomson-7805cv-stm
IC4: ebay
Q1-Q8: IRF52 má jen někdo, ale jak jsi hledal už v http://www.ebastlirna.cz/modules.php?name=Forums&file=viewtopic&t=80205, tak by IRF520 mohl vyhovět: https://www.gme.cz/unipolarni-tranzistor-irf520-to220
Q9: https://www.gme.cz/krystal-hc49-u-q-16mhz
Q10-Q26: IRF52 má jen někdo, ale jak jsi hledal už v http://www.ebastlirna.cz/modules.php?name=Forums&file=viewtopic&t=80205, tak by IRF520 mohl vyhovět: https://www.gme.cz/unipolarni-tranzistor-irf520-to220
R12, R13, R30-R33: https://www.gme.cz/rm-10k-0204-0-4w-1-yageo
RN-RN3: https://www.gme.cz/rra-8x10k-2
X1-X11, X13-X16, X28: https://www.gme.cz/svorkovnice-sroubovaci-do-dps-ark300v-2p
X12, X17-X21: https://www.gme.cz/svorkovnice-sroubovaci-do-dps-ark300v-3p
Karya
PříspěvekZaslal: so duben 22 2017, 6:34    Předmět: Citovat
Dik dik dik na 100 krat
Este som dohodil paticu.
https://www.gme.cz/sokl-24u
Karya
PříspěvekZaslal: so duben 22 2017, 6:43    Předmět: Citovat
Karya
PříspěvekZaslal: so duben 22 2017, 6:53    Předmět: Citovat
V com je lebsi? Procesor mal by ist naprogramovat v Arduine Uno.
Cowley
PříspěvekZaslal: so duben 22 2017, 7:24    Předmět: Citovat
Michal je prostě světec Smile
sinclair
Založen: Feb 02, 2005
PříspěvekZaslal: so duben 22 2017, 8:58    Předmět: Citovat
Já bysem zas za nic na světě, ani za pytel dalekohledů nešel do Hitana.
Radíte mu pěkný věci, chudákovi.
Ecom a Semic pro Vás nejsou dost dobrý firmy?
PříspěvekZaslal: so duben 22 2017, 9:01    Předmět: Citovat
Světci si nedají v páteční večer 8 ležáků Very Happy
Ještě bych mě doplnění- ty elyty 1000µF, tam by chtělo vědět, kde jsou použity. Pokud za stabilizátorem 7805, tak je zbytrečné tam cpat tak veliký, stačilo by třeba 470µF, klidně na 10V.
Ale z toho schematu a osazováku to nejsem schopen vyčíst.
Sinclaire, jsou i horší značky elytů Very Happy
Cowley
PříspěvekZaslal: so duben 22 2017, 10:39    Předmět: Citovat
Ja nejsem schopen vycist ty D1-D3...
Muzes sem, prosim, dat link na ty puvodni stranky?
PříspěvekZaslal: so duben 22 2017, 12:01    Předmět: Citovat
No vida, D až D3 v rozpisce nejsou. Ale podle schematu by to měly být transily, tipuju jednosměrné 6V8.
