Založen: Jul 13, 2014 Příspěvky: 364 Bydliště: Petřvald U NJ
Zaslal: ne únor 28 2016, 11:05 Předmět: Indentifikace neznámého zařízení
Dobrý den všem přistálo mi na stole neznámé zařízení ani původní majitel netuší o co by mohlo jít má to z pozůstalosti.. Neporadí někdo či nenavede o co by mohlo jít ? Viz příloha http://ok2mlo.rajce.idnes.cz/Nezname_zarizeni/
M
Založen: Feb 08, 2005 Příspěvky: 7968 Bydliště: rovina u Kolína
Zaslal: ne únor 28 2016, 11:36 Předmět:
Vypadá to VF zesilovač výkonu. Otázka je jaké pásmo, CB, VHF, KV? Určitě někdo vyhledá podle ročníku časopisu. _________________ ..to bude jen ňákej odpůrek
SITUATED at the low end of the VHF band, the amateur radio frequency segment between 50 and 52 MHz has some very exciting propagation characteristics. Thanks to atmospheric reflection, transcontinental radio contacts using very low powers have been made 'on six'. Radio amateurs war king on the VHF and UHF bands know that the reception quality of signals from VHF Band-I (48-68 MHz) TV transmitters can rise within minutes from very poor to quite acceptable. This often happens in the summer and early autumn, when there are temperature inversions in certain layers of the atmosphere. In the UK, where the VHF-I band is 110 longer used for TV broadcast services, it is common practice among VHF radio amateurs to monitor the field strength of certain Dutch and Spanish TV transmitters.
First, the syncs are audible, then the pictures seem to arise from the noise.
The next thing to do is get the logbook out and the rtg ready since it is often only a matter of hours before long periods of sporadic-E reflection enable contacts to be made over distances of hundreds of miles in the 2-m band.
A quite different type of propagation, TEP (trans-equatorial propagation), carries 6-m signals across the oceans, reaching stations thousands of miles away. Contacts have been made between European radio amateurs end stations in Rhodesia, South Africa, Namibia and Brazil. using CW on six metres.
In Europe, equipment for the 6-m band is mostly of the home-brew type, although Japanese 'black box' transceivers are starting to become available. The 6-m band is not crowded and equipment being mostly experimental with modest transmit power there is a certain distinction in being QRV on six...
Možná jsem ještě něco přehlédl a neopravil, ale dávat sem needitovaný sken převedený OCRkou a ještě tomu textu nezrušit formátování, to nám příště nedělej, prosím.
Navíc se mi podařilo při editaci smazat schéma, vlož ho prosím, znovu.
Jo jo, já to vzal, jak to bylo v tom elektoru přes kopírovat a vložit. A potom jsem zkusil dát značku toho amatéra do vyhledávače a našel odkazy co jsou v dalším příspěvku.
Založen: Nov 28, 2006 Příspěvky: 12102 Bydliště: Česká Třebová
Zaslal: po únor 29 2016, 21:32 Předmět:
deska je stejná na 100%
ale jeho použití, na které pásmo to je, poznáš až podle naladění obvodů.
změř kmitočet transpozice před balančákem a uvidíš . . .
a ten PA je postaven ze zbytků VR20 nebo VR20/50
ta měla vnitřnosti na 24V(tranzistory KT922B a z 12V palubní sítě bylo upravováno měničem s tranzistorem KUxxx
ten výstupní filtr který má zespoda relátko je v téměř originálním stavu jako ve VR20 . . .
