Pickit 3 - debugger nefunguje
dudo02
Založen: Feb 27, 2007
PříspěvekZaslal: ne prosinec 20 2015, 13:42    Předmět: Pickit 3 - debugger nefunguje Citovat
The target device is not ready for debugging.
Please check your configuration bit settings and program
the device before proceeding.
Stepping target failed
Tuto hlasku mi vypise MPLAB pri pokuse o debugovanie.
Debugger skusam prvy raz, cize som ho este nemal nikdy funkcny.
O error hlaske je na nete kopec, skusal som menit configuracne nastavenia, ale nefunguje nic...
Skusam to aj s uplne jednoduchym programom LED_BLINK - v code.
Mohol by niekto prosim program skusit u seba, ci nemam nejaky problem s hardverom?Popr. poslat nejaky program, ktory je u neho funkcny na jeho PC...
Pri pokuse o nejaku operaciu(napr.STEP IN), sa LED dioda rychle rozblika az postupne zhasne.Potom uz blika podla programu a debugovanie nefunguje...
kód:
; Processor: PIC16F628 at 4 MHz using internal RC oscillator
; Function:  Flash a LED connected to RA2
; Hardware:  Testboard K4
; Filename:  628LED.asm
; Author:    Lars Petersen, oz1bxm@pobox.com
; Website:   www.qsl.net/oz1bxm/PIC/pic.htm
; Credit:    Tony Nixon's LED flasher
        LIST P=16F628, R=DEC    ; Use the PIC16F628 and decimal system
        #include "P16F628.INC"  ; Include header file
        __config  _INTRC_OSC_NOCLKOUT & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
        CBLOCK 0x20             ; Declare variable addresses starting at 0x20
          Loop1,Loop2
        ENDC
; INITIALIZE
        ORG    0x000           ; Program starts at 0x000
        CLRF   PORTA           ; Initialize port A
        CLRF   PORTB           ; Initialize port B
        BSF    STATUS,RP0      ; RAM bank 1
        CLRF   TRISA           ; All pins port A output
        CLRF   TRISB           ; All pins port B output
        BCF    STATUS,RP0      ; RAM bank 0
; FUNCTION OF PORT A PINS
        MOVLW    7
        MOVWF    CMCON         ; Comparators off, all pins digital I/O
; MAIN LOOP
Main    BSF     PORTA,2        ; Turn on LED connected to RA2
        CALL    delay
        BCF     PORTA,2        ; Turn off LED connected to RA2
        CALL    delay
        GOTO    Main
; DELAY 250 MSEC
delay   MOVLW   250
        MOVWF   Loop1
Outer   MOVLW   200
        MOVWF   Loop2
Inner   NOP
        NOP
        DECFSZ  Loop2,F
        GOTO    Inner          ; Inner loop = 5 usec.
        DECFSZ  Loop1,F
        GOTO    Outer
        RETURN
        END
OK 22-9-2002.
Assembler: Microchip MPASM 3.00
Programmer: P16PRO40 (Bojan Dobaj)
Programmer software: WinPicProg 1.9 (Nigel Goodwin)
frpr666
Založen: Dec 28, 2009
PříspěvekZaslal: ne prosinec 20 2015, 14:59    Předmět: Citovat
Nepíšeš, jesti ti ICD adaptér nefunguje od začátku, nebo jen v tomto konktrétním případě.
Ten program výše se zdá v pořádku. Má blikat LED na pinu RA2.
Zkus to zkompilovat a nahrát do MCU.
Nejdříve to zkus bez debugu, tím poznáš že MCU žije.
Potom u debugu dej "toggle breakpoint" např. na Main a pak "Run"
Po každé otočce cyklu (bliknutí LED) se měl program "zastavit" (halt).
Pokud né, je něco špatně.
Pořádně si pročti návod k tvému ICD adaptéru.
Počítej s tím, že ICD debug samotný na chipu má svou vlastní režii a "sežere" nějaký čas práce MCU.
 Soubor:  151220mplab.jpg
 Velikost:  80.8 kB
 Staženo:  81 krát
dudo02
PříspěvekZaslal: ne prosinec 20 2015, 15:17    Předmět: Citovat
dudo02 napsal(a):
Ja skusam debugger bez ICD adapteru(pocujem o nom prvy krat)- myslel som ze to funguje cez ICSP. Nefunguje?
Boze ja som LAMA Razz
frpr666
PříspěvekZaslal: ne prosinec 20 2015, 16:48    Předmět: Citovat
MPLAB studio má i simulátor: MPLAB SIM. Tam si lze "krokovat" program i bez ICD adaptéru.
dudo02
PříspěvekZaslal: ne prosinec 20 2015, 16:52    Předmět: Citovat
Jj, no ale pokial clovek vidi, ako sa konkretny vystup sprava, je to o inom...
Akurat som si nainstaloval MPLAB X a pozeram to C-ecko.
Vyzera to naozaj jednoduchsie ako ASM. ...
frpr666
PříspěvekZaslal: út prosinec 22 2015, 11:13    Předmět: Citovat
To je pravda 16F628 ICD debug neumí. Píšou to v DS. Zkus jinačí součástku třeba: 16F874. Nebo přejdi rovnou na Atmel a máš klid. Very Happy
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:14    Předmět: Citovat
Kde si to nasiel v datasheete?
Tu sa uvadza nieco ine - http://www.digikey.com/product-detail/en/AC162053/AC162053-ND/551720.MPLAB X mi ponuka na vyber v menu SUPPORTED DEBUG HEADER presne to iste..
Pracujem s PIC16F628A,akurat ten LEDBLINK bol na 16F628...
frpr666
PříspěvekZaslal: út prosinec 22 2015, 11:22    Předmět: Citovat
14.13 In-Circuit Debugger
Since in-circuit debugging requires the loss of clock,data and MCLR pins, MPLAB ICD 2 development with
an 18-pin device is not practical. A special 28-pin
PIC16F648A-ICD device is used with MPLAB ICD 2 to
provide separate clock, data and MCLR
pins and frees
all normally available pins to the user. Debugging of all
three versions of the PIC16F627A/628A/648A is
supported by the PIC16F648A-ICD
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:32    Předmět: Citovat
http://www.digikey.com/product-detail/en/PIC16F628A-I%2FP/PIC16F628A-I%2FP-ND/529766Tak presne tieto mam doma a toto je odkaz ktory najdes v odkazoch nizsie.Okrem toho su tam aj dalsie 18pin verzie...
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:36    Předmět: Citovat
frpr666 napsal(a):
pins and frees
Kde sa tam pise ze nie je podporovany?
Pisu ze debug je neprakticky a ze vsetky 3 verzie su podporovane specialnym zariadenim-PIC16F648A-ICD ...
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:40    Předmět: Citovat
SIM pouzivam a v spojeni so Stimulusom v MPLABX je celkom fajn...
Naposledy upravil dudo02 dne út prosinec 22 2015, 11:45, celkově upraveno 1 krát.
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:42    Předmět: Citovat
Tak teraz ako? Neviem po anglicky ja, alebo vy? Laughing
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:54    Předmět: Citovat
No nie, nemyslim si ze kecas. No mylit sa moze kazdy...
Vsak najprv si napisal ze normalne verzie nejdu debugovat vobec-len nejake specialne s navyse pinmi.
Teraz si napisal ze debugovat idu- so specialnym headerom.S tym v odkaze.
Cize 16F628A sa debugovat da.
No offense.
dudo02
PříspěvekZaslal: út prosinec 22 2015, 11:57    Předmět: Citovat
Ale na tie moje par-riadkove pokusy mi uplne postacuje simulator.
Ja som totiz myslel, ze na debug nie je potrebny ziaden dalsi hardware.
