PIC-Problem s nastavenim portov.
dudo02
Založen: Feb 27, 2007
PříspěvekZaslal: po prosinec 14 2015, 11:24    Předmět: PIC-Problem s nastavenim portov. Citovat
Zdravim,
Snazim sa naprogramovat casovac,ktory bude ovladat bodovu zvaracku.
Pracujem v MPLABe.
Procesor PIC16F628A.
Mam problem s nastavenim portov A ako vstupnych a to konkretne A0, A1, A2, A3.Planujem na nich napojit pull-upp rezistory.
Program ako je napisany v code funguje korektne pokial sa nepokusim spominane porty v programe pouzit.
V datasheete sa uvadza:
2: On Reset, the TRISA register is set to all
inputs. The digital inputs (RA<3:0>) are
disabled and the comparator inputs are
forced to ground to reduce current
consumption.
Cize pravdepodobnym dovodom preco program blbne je to ze su porty vypnute,popr. to ze su povolene komparatory.
Na a neviem vycitat z datasheetu ako porty zapnut, popr.deaktivovat komparatory, alebo co vlastne robit
kód:
; Projekt: Bodovacka
 LIST   p=16F628A          ;type of processor
#INCLUDE   <P16F628A.INC>   ; definitoins
; configguration bits settings
 __CONFIG _PWRTE_ON & _WDT_OFF & _MCLRE_OFF & _BODEN_OFF & _LVP_OFF & _INTRC_OSC_NOCLKOUT
; definitions
#DEFINE   OPT    PORTA,2  ;optocoupler
#DEFINE   LED    PORTA,3  ;led
#DEFINE FOOT   PORTA,6  ;foot switch
#DEFINE SW1    PORTB,7  ;SW1-SW11 rotary switch
#DEFINE SW2    PORTB,6
#DEFINE SW3    PORTB,5
#DEFINE SW4    PORTB,4
#DEFINE SW5    PORTB,3
#DEFINE SW6    PORTB,2
#DEFINE SW7    PORTB,1
#DEFINE SW8    PORTB,0
#DEFINE SW9    PORTA,7
#DEFINE SW10   PORTA,5
#DEFINE SW11   PORTA,4
 CBLOCK 0X20
 D1
 D2
 ENDC
;program
 RESET ORG 0x0000      ; start program on adress 0000h
;inicializacia portov
 BSF STATUS,RP0
 BCF OPTION_REG, 7   ; enable internal pullups
 MOVLW b'11110011'   ; RA1,RA2=OUT, rest=IN
 MOVWF TRISA
 MOVLW b'11111111'   ; RB0-7= all IN
 MOVWF TRISB
 BCF   STATUS,RP0
 GOTO START
;podprogram DELAY 50ms
DELAY   MOVLW   0x0F
        MOVWF   D1
       MOVLW   0x28
        MOVWF   D2
DELAY_0 DECFSZ   D1, F
       goto   $+2
       decfsz   D2, F
       goto   DELAY_0
;2 cycles
       GOTO   $+1
       RETURN   ; return when if d1=0
;Podprogramy DELAYs
DELAY_50   BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_100  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         BCF  LED
         RETURN
DELAY_150  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_200  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_250  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_300  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_350  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_400  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_450  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
DELAY_500  BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BCF  OPT
         RETURN
NON_STOP   BSF  OPT
         CALL DELAY
         BCF  OPT
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         CALL DELAY
         BSF   OPT
         BTFSS FOOT
         GOTO  $-1
         BCF   OPT
         RETURN
;main program
START   BSF     LED
        CALL    DELAY
       BCF     LED
       CALL    DELAY
       CALL    DELAY
       CALL    DELAY
       CALL    DELAY
       CALL    DELAY
       CALL    DELAY
       CALL    DELAY
       CALL    DELAY
       BCF     LED
      BTFSC   FOOT
       GOTO    START
       BTFSS   SW1
       CALL    DELAY_50
       BTFSS   SW2
       CALL    DELAY_100
       BTFSS   SW3
       CALL    DELAY_150
       BTFSS   SW4
       CALL    DELAY_200
       BTFSS   SW5
       CALL    DELAY_250
       BTFSS   SW6
       CALL    DELAY_300
       BTFSS   SW7
       CALL    DELAY_350
       BTFSS   SW8
       CALL    DELAY_400
       BTFSS   SW9
        CALL    DELAY_450
        BTFSS   SW10
        CALL    DELAY_500
        BTFSS   SW11
        CALL    NON_STOP
       BTFSS   FOOT
       GOTO    $-1
       GOTO    START
        END
mikollar
Založen: Dec 26, 2004
PříspěvekZaslal: po prosinec 14 2015, 11:44    Předmět: Citovat
Mas to priamo v katalogu
kód:
CLRF PORTA ;Initialize PORTA by
;setting
;output data latches
MOVLW 0x07 ;Turn comparators off and
MOVWF CMCON ;enable pins for I/O
;functions
BCF STATUS, RP1
BSF STATUS, RP0 ;Select Bank1
MOVLW 0x1F ;Value used to initialize
;data direction
MOVWF TRISA ;Set RA<4:0> as inputs
;TRISA<5> always
;read as ‘1’.
;TRISA<7:6>
;depend on oscillator
;mode
dudo02
PříspěvekZaslal: po prosinec 14 2015, 21:20    Předmět: Citovat
Vdaka, programovat zacinam a nebol som si isty. Funguje to,tak ako ma.
petrfilipi
Založen: Sep 13, 2005
PříspěvekZaslal: st prosinec 16 2015, 20:20    Předmět: Citovat
Je to v datasheetu na straně 54 - viz obrázek. Musíš nastavit bity 0,1,2 registru CMCON na 1, abys měl PortA jako digitální.
PF
 Soubor:  Komparátor 16F628.jpg
 Velikost:  137.46 kB
 Staženo:  104 krát
