Trafo do tunera
PříspěvekZaslal: pá leden 16 2015, 12:02    Předmět: Citovat
http://www.cutestudio.net/data/products/audio/Retro_Hi-Fi/sony_st313l/index.php
The tuner is pretty cool, having special electro-magnetic preset markers, one set for FM, one for AM. You tune up to one, grab it by pressing a button, and slide it along as you tune. You can then select FM/MW/LW/SW or Auto. Auto mode looks at the markers as you tune and switches bands as you get to them.
vladodyno
Založen: Feb 25, 2010
PříspěvekZaslal: pá leden 16 2015, 14:27    Předmět: Citovat
yesper26
Založen: May 19, 2012
PříspěvekZaslal: po leden 19 2015, 14:36    Předmět: Citovat
Trafo prehodene Smile , hned aj lepsie bassuje a aj signal ma lepsi Smile Smile
