termostat displej na pind
SimonHosa
Založen: Jul 22, 2014
PříspěvekZaslal: ne srpen 17 2014, 20:38    Předmět: termostat displej na pind Citovat
Dobrí večer stále riešim môj termostat a ,už ho skoro mám LCD som napojil podla schémy http://svetelektro.com/clanky/programujeme-avr-v-jazyku-c-6-cast-459.html potom som upravil program na voltmeter http://svetelektro.com/clanky/programujeme-avr-v-jazyku-c-7-cast-472.html a stále ukazovalo 500C°.pretože prevodník je na pinc toto je ten program:
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include <stdlib.h>
#include <stdio.h>
#include "lcd.h"
#include "lcd.c"
#define LCD_LINES 2
#define LCD_DISP_LENGTH 16
#define LCD_LINE_LENGTH 0x40
#define LCD_START_LINE1 0x00
#define LCD_START_LINE2 0x40
#define LCD_START_LINE3 0x14
#define LCD_START_LINE4 0x54
#define LCD_WRAP_LINES 0
#define LCD_PORT PORTD
#define LCD_DATA0_PORT LCD_PORT
#define LCD_DATA1_PORT LCD_PORT
#define LCD_DATA2_PORT LCD_PORT
#define LCD_DATA3_PORT LCD_PORT
#define LCD_DATA0_PIN 3
#define LCD_DATA1_PIN 2
#define LCD_DATA2_PIN 1
#define LCD_DATA3_PIN 0
#define LCD_RS_PORT PORTD
#define LCD_RS_PIN 5
#define LCD_E_PORT PORTD
#define LCD_E_PIN 4
unsigned int Read_ADC(unsigned char channel){
// vloz cislo kanala, vymaskuj nepouzite bity
ADMUX &= 0xF0;
ADMUX |= channel & 0x0F;
// start conversion
ADCSRA |= (1 << ADSC);
// cakaj na priznak skoncenia konverzie
while(!(ADCSRA & (1<<ADIF)));
// navratova hodnota - vysledok ad prevodu
return ADC;
int main(){
char text[32];
unsigned int T,adc;
ADMUX |= (1 << REFS0); //referencia 5V
// povolenie AD prevodnika, Interrupt flag, preddelicka 128 pri frekvencii hodin 8MHz
ADCSRA |= (1 << ADEN) | (1 << ADIF) | (1 <<ADPS2) | (1 <<ADPS1) | (1 <<ADPS0);
sei(); // povol globalne prerusenia
lcd_init(LCD_DISP_ON);
while(1){
adc = Read_ADC(0);
// vypocet napatia v mV
T = ((long)adc*5000/1024/10);
sprintf(text,"Teplota: \n%dC*",T);
lcd_clrscr();
lcd_gotoxy(0,0);
lcd_puts(text);
_delay_ms(500);
pri tamtom programe Na displeji mi ukazuje PPPPPPPPPPPPPPPP
PPPPPPPPPPPPPPPP
pri programe:
#include <avr/io.h>
#include <stdlib.h>
#include <stdio.h>
#include "lcd.h"
#include "lcd.c"
ADMUX &= 0xF0;
// start conversion
return ADC;
int main(){
char text[32];
unsigned int T,adc;
while(1){
adc = Read_ADC(0);
lcd_clrscr();
lcd_gotoxy(0,0);
lcd_puts(text);
_delay_ms(500);
to ide ale nemôžem napojit čidlo a stále ukazuje 499c° ,lebo do pc0 nejde čidlo ale DB7 prosím o radu čo mám zle??
frpr666
Založen: Dec 28, 2009
PříspěvekZaslal: ne srpen 17 2014, 21:49    Předmět: Citovat
pokud program nefunguje jak má, potom je třeba jej zjednodušit, odzkoušet, a tak najít chybu.
Samotný výpis na displej ti funguje?
kód:
int main() {
  char text[32];
  unsigned int T,adc;
  T = 111;
  sprintf(text,"Teplota: %dC",T);
  lcd_clrscr();
  lcd_gotoxy(0,0);
  lcd_puts(text);
  while(1)
FHonza
Založen: Nov 20, 2012
PříspěvekZaslal: po srpen 18 2014, 10:40    Předmět: Citovat
V první řadě uzemni vývody displeje DB0 až DB3, dost řadičů bez toho nefunguje.
Jestli se řídíš tímto schematem, tak tomu nerozumím. Tam je displej připojen na PORTD. Podle toho musíš upravit i soubor lcd.h takto:
kód:
#define LCD_PORT         PORTD        /**< port for the LCD lines   */
#define LCD_DATA0_PORT   LCD_PORT     /**< port for 4bit data bit 0 */
#define LCD_DATA1_PORT   LCD_PORT     /**< port for 4bit data bit 1 */
#define LCD_DATA2_PORT   LCD_PORT     /**< port for 4bit data bit 2 */
#define LCD_DATA3_PORT   LCD_PORT     /**< port for 4bit data bit 3 */
#define LCD_DATA0_PIN    2            /**< pin for 4bit data bit 0  */
#define LCD_DATA1_PIN    3            /**< pin for 4bit data bit 1  */
#define LCD_DATA2_PIN    4            /**< pin for 4bit data bit 2  */
#define LCD_DATA3_PIN    5            /**< pin for 4bit data bit 3  */
#define LCD_RS_PORT      PORTD        /**< port for RS line         */
#define LCD_RS_PIN       0            /**< pin  for RS line         */
#define LCD_E_PORT       PORTD        /**< port for Enable line     */
#define LCD_E_PIN        1            /**< pin  for Enable line     */
SimonHosa
PříspěvekZaslal: po srpen 18 2014, 14:02    Předmět: Citovat
radič funguje aj vypisovanie funguje ale pinc 0 ide na display a zároven z neho aj prevodník číta,takže tam mám 500C° mne treba previest displej z pinouc na pinid a to mi nejde odfotím vám čo to ukazuje momentík.
FHonza
PříspěvekZaslal: po srpen 18 2014, 14:09    Předmět: Citovat
No vždyť sem ti to psal o příspěvek výš, přehoď displej na PORTD. V odkazu co jsi posílal, je připojen právě na PORTD. Když použiješ zapojení dle toho schématu, tak jenom upravíš soubor lcd.h tak, jak jsem psal výše. Nic složitého na tom není. A logicky nemůžeš mít připojený displej i čidlo na stejný pin. No a protože jenom PORTC se zároveň dá použít jako vstup A/D, tak musíš přesunout displej.
SimonHosa
PříspěvekZaslal: po srpen 18 2014, 14:20    Předmět: Citovat
ja viem že ho musím posunút ale tie definície nefungujú tu je foto http://dpssimonhosa.blogspot.sk/
FHonza
PříspěvekZaslal: po srpen 18 2014, 14:27    Předmět: Citovat
Nahraj sem schéma tvého zapojení, jinak se ničeho nedobereme.
SimonHosa
PříspěvekZaslal: po srpen 18 2014, 14:36    Předmět: Citovat
Napálil som program:
#include <avr/io.h>
#include <stdlib.h>
#include <stdio.h>
#include "lcd.h"
#include "lcd.c"
ADMUX &= 0xF0;
// start conversion
return ADC;
int main(){
char text[32];
unsigned int T,adc;
while(1){
adc = Read_ADC(0);
lcd_clrscr();
lcd_gotoxy(0,0);
lcd_puts(text);
_delay_ms(500);
A stále ukazuje na pinc
SCHÉMA:
Naposledy upravil SimonHosa dne po srpen 18 2014, 14:41, celkově upraveno 1 krát.
FHonza
PříspěvekZaslal: po srpen 18 2014, 14:41    Předmět: Citovat
Co ukazuje na pinc ? Netuším co tím myslíš. A jak sem psal, nahraj sem svoje schema.
SimonHosa
PříspěvekZaslal: po srpen 18 2014, 14:42    Předmět: Citovat
No ,že displej ide stále na pinochc a na pinochd nie.Striedam 2 zapojenia to hore mam stale a ked displej nejde tak skúsim toto
FHonza
PříspěvekZaslal: po srpen 18 2014, 14:48    Předmět: Citovat
A přepsal si soubor lcd.h nebo ty definice máš v hlavním programu ? A jestli v hlavním programu, tak jsi koukal na varování co ti překladač vypisuje ?
SimonHosa
PříspěvekZaslal: po srpen 18 2014, 14:51    Předmět: Citovat
Hodil som to do hlavného a boli tam varovania.
FHonza
PříspěvekZaslal: po srpen 18 2014, 14:57    Předmět: Citovat
No a sme u toho. Ty varování tam nejsou jen tak... Tím, že máš nejdříve uvedeno
kód:
#include "lcd.h"
tak se konstanty LCD_xxx definují dle souboru lcd.h. A další definici překladač ignoruje s varováním, že takové konstanty jsou již definovány. Proto jsem ti psal
A ještě doplním, kvůli tomu soubory *.h existují. Pro každý projekt máš dle zapojení různý lcd.h, ale jenom jeden společný lcd.c.
SimonHosa
PříspěvekZaslal: po srpen 18 2014, 15:06    Předmět: Citovat
takže to čo si napísal mam dat do začiatku lcd.h a za #include .... v hlavnom programe??
FHonza
PříspěvekZaslal: po srpen 18 2014, 15:13    Předmět: Citovat
V tom lcd.h to nějak je. A to změň podle toho, jak sem ti psal. Ty konstanty LCD_xxx definují na který pin a který port jsou připojeny jednotlivé vývody displeje. Je to uvedeno i v komentářích.
