Pomoc s turbopascalom
mety
Založen: Mar 06, 2005
PříspěvekZaslal: čt listopad 18 2010, 18:24    Předmět: Pomoc s turbopascalom Citovat
Zdravim všetkych.
Potreboval by som pomôcť s turbopascalom.
Konkretne ide o premennu "b" v priloženom kode programu.
Po spustení programu sa hodnota premenny "b" výpíše viac krát ta ista pod seba.
Ja ju potrebujem vypísať len raz.
Neviete niekto pomôcť kde mam chybu?
Lebo keď dam vypisať hodnotu "oneskorenie" priamo:
writeln(oneskorenie [i] ) vypiše sa hodnota správne len raz.
Ako náhle priradim hodnotu oneskorenie premennej
b:=(oneskorenie[i]) , vypiše mi to viac krát pod seba Sad
Tu je samotný program:
kód:
Program test;
uses crt;
var a:word;
    i:byte;
    c,b:word;
const oneskorenie : array [1..165] of word =
(5,5,5,5,5,6,6,6,6,6,6,6,6,6,6,6,6,6,6,
6,6,6,7,7,7,7,7,7,7,7,7,7,7,8,8,8,8,8,8,8,
8,9,9,9,9,9,9,9,10,10,10,10,10,10,11,11,11,
11,12,12,12,12,13,13,13,13,14,14,14,14,14,15,
15,15,15,16,16,16,16,17,17,17,18,18,18,19,19,
19,20,20,20,21,21,22,22,23,23,24,24,25,25,26,
26,27,27,28,28,29,29,30,30,31,31,32,33,33,34,
35,36,36,37,38,39,40,41,42,43,44,45,46,48,49,
50,52,54,55,57,59,61,63,66,68,71,74,77,80,84,
88,92,97,102,108,115,122,130,139,150,163,177,
185,194,204,215,227,241);
const ctIN : array [1..166] of word =
(100,102,103,105,107,109,110,111,112,113,114,
115,117,118,119,120,121,122,124,125,126,128,
129,130,132,133,135,136,138,140,141,143,145,
146,148,150,152,154,156,158,160,162,164,167,
169,171,174,176,179,182,185,188,190,194,197,
200,203,207,211,214,218,222,226,231,235,240,
245,248,251,254,258,261,264,268,271,275,279,
283,287,291,296,300,305,309,314,319,324,330,
335,341,347,353,359,366,373,380,387,395,403,
411,420,429,435,441,448,455,462,469,476,484,
492,500,508,517,526,536,545,556,566,577,588,
600,612,625,638,652,667,682,698,714,732,750,
769,789,811,833,857,882,909,938,968,1000,1034,
1071,1111,1154,1200,1250,1304,1364,1429,1500,
1579,1667,1765,1875,2000,2143,2308,2500,2609,
2727,2857,3000,3158,3333) ;
begin
clrscr;
write('Zadaj hodnotu:');
readln(a);
for i:=1 to 165 do
begin
if (a>=ctIN [i]) AND (a<ctIN [i+1]) then b:=(oneskorenie[i]) ;
writeln(b);
end;
repeat until keypressed;
end.
PříspěvekZaslal: čt listopad 18 2010, 18:45    Předmět: Citovat
To je logický, k "i" přičítáš jen jedničku, zatímco interval máš třeba 5. Nastav si po výpisu nějakej příznak (třeba d:=1) a dej to jako podmínku pro writeln.
readln(a);
d:=0;
for i:=1 to 165 do
begin
if (a>=ctIN [i]) AND (a<ctIN [i+1]) and (d=0) then
begin
writeln(b);
d:=1;
end;
end;
mety
PříspěvekZaslal: čt listopad 18 2010, 18:56    Předmět: Citovat
Diky za radu , funguje to Smile
pocitujlasku
Založen: Dec 12, 2005
PříspěvekZaslal: čt listopad 18 2010, 21:40    Předmět: Citovat
este drobnost, ktora mi hned udrela do oci:
kód:
zbytocne vytazi procak na 100%, namiesto toho pouzi
kód:
readln;
No vidis, a tak si sa bal
PříspěvekZaslal: pá listopad 19 2010, 9:47    Předmět: Citovat
Když jsme u toho zatížení, je tam možnost použít cyklus
i:=0;
repeat
i:=i+1;
until (d=1) or (i=165);
takže to skončí hned, jak to najde správnou hodnotu.
