Verze Bascomu a schopnost pracovat s různými AVR
Crifodo
Založen: Oct 11, 2005
PříspěvekZaslal: po říjen 25 2010, 11:22    Předmět: Verze Bascomu a schopnost pracovat s různými AVR Citovat
Jaké máte zkušenosti se zvládáním různých typů čipu různými verzemi programu? Nenašel jsem nikde výslovně uvedeno, které příkazy a konfigurace daná verze podporuje a které ne (není to otázka definičního souboru k procesoru).
ivanko18
Založen: May 31, 2009
PříspěvekZaslal: po říjen 25 2010, 13:01    Předmět: Citovat
2.0.1.0 zatial funguje vsetko
- 1wire changed so it works with Xmega as well.
- various samples in the samples\xmega folder
- bug in $swcheck fixed. the soft stack is now checked from within the other stack check routines which saves code.
- xm32A4 added, thanks MAK3 !
- getadc() for Xmega has an additional parameter so it can pass both channel and mux.
- $NORAMPZ will result in rampz treating as 1.12.0.0. In 2.0.0.0 the rampz is cleared after it has been used for pointing to flash memory.
If your app worked fine and you can not allow the extra code you can use the directive.
- xmega EBI(xram) support added. See config XRAM. Don't be intimidated by the number of options, just use the sample.
- config clock uses the RTC now of the Xmega. See the xm128-RTC.bas example
- watchog support added for XMega. See the sample xm128-WD.bas
- added DISABLE JTAG to disable the jtag interface via software. this works for normal and xmega chips.
- $forcesofti2c will force the xmega to use software i2c, it was used internally. it will not be added to the help.
- adding array index support feature resulted in a bug when using locals
- lcdvdf.lib added for a special VFD display module from "Electronic Design Bitzer". LCDAUTODIM added.
this is a 20x4 vfd display immune for ESD.
config lcdpin creates constants for the pins which are used by the lib. also MODE added for 20x4VFD.
you can also define busy for a busy pin. this is a fragment from a lib that shows the generated names. they are also visible in the report.
sbi _lcddb4dir, _lcddb4_pin ; db4
sbi _lcddb5dir, _lcddb5_pin ; db5
sbi _lcddb6dir, _lcddb6_pin ; db6
sbi _lcddb7dir, _lcddb7_pin ; db7
sbi _lcddbedir, _lcddbe_pin ; enable/strobe HIGH
sbi _lcdresetdir,_lcdreset_pin ; reset line to Output
sbi _lcddbe, _lcddbe_pin ; strobe high
cbi _lcdreset,_lcdreset_pin ; reset low
sbi _lcdreset,_lcdreset_pin ; reset was LOW so make it HIGH
- when not ubrhi setting updated the wrong register for chips with shared registers.
- config DP="," | "." to select the decimal point for the fusing() and single str() functions. Default is "."
- i2crepstart did not work for Xmega
- i2cstop for xmega did not free bus after i2creceive/i2csend, so the i2cstop command has been extended to send multiple commands.
nekmil
Založen: Mar 06, 2005
PříspěvekZaslal: po říjen 25 2010, 17:43    Předmět: Citovat
Ona už je verze 2.0.1.0 ? Nějak jsem zaspal. Používám Attiny2313, Atmega8, Atmega8535, Atmega644, Atmega32 a zatím není problém. A máme tu dát výpisy "History" u jednotlivých verzí ? Pochopitelně příkaz pro AD převodník nebude fungovat u procesoru který ho nemá Smile
ivanko18
PříspěvekZaslal: po říjen 25 2010, 18:04    Předmět: Citovat
Ten kto ma kupene moze pracovat v aktualnej 2.0.1.0 .Je to volne stiahnutelne ako update
Naposledy upravil ivanko18 dne po říjen 25 2010, 19:45, celkově upraveno 3 krát.
Crifodo
PříspěvekZaslal: po říjen 25 2010, 18:11    Předmět: Citovat
A není ta 2.0.1.0 pro 51? já tu řeším avr Rolling Eyes na stránkách MCS je nejvyšší verze 1.11.9.8.
ivanko18
PříspěvekZaslal: po říjen 25 2010, 18:14    Předmět: Citovat
ty stahujes demo ja mam stiahnutu poslednu platenu verziu ta je novsia
Zbytečná citace celého předchozího příspěvku vymazána.
nekmil
PříspěvekZaslal: po říjen 25 2010, 18:34    Předmět: Citovat
Teď jsem si vzpoměl že, nechtěl fungovat "getrc5" na Timeru 0 na Atmega644, asi chyba v definičním souboru.
tohle to spravilo
$asm
.equ Timsk = Timsk0
$end Asm
potvrzuji 2.0.1.0 je pro avr
