PWM
mirecc
Založen: Nov 13, 2006
PříspěvekZaslal: st prosinec 16 2009, 18:36    Předmět: PWM Citovat
Mam jeden problem robil som program na PWM na C/C2 pre atmega8, len mi to pwm nejde, neviete mi poradit???
Tu je program>
#include <C:\WinAVR-20090313\avr\include\avr\io.h>
#define increaseButton_PRESSED !(PIND & 0x40)
#define increaseButton_OPEN (PIND & 0x40)
#define decreaseButton_PRESSED !(PIND & 0x80)
#define decreaseButton_OPEN (PIND & 0x80)
#define COUNTER_MIN 0x0090
#define COUNTER_MAX 0x00f8
#define KROK 0x0008
void port_init(void)
PORTB = 0x00;
DDRB = 0x08;
PORTC = 0x00;
DDRC = 0x00;
PORTD = 0xC0;
DDRD = 0x00;
void timer2_init(void)
TCCR2 = 0x61; //setup
OCR2 = COUNTER_MIN;
void init_devices(void)
//stop errant interrupts until set up
//CLI(); //disable all interrupts
port_init();
timer2_init();
//MCUCR = 0x00;
//GICR = 0x00;
//TIMSK = 0x00; //timer interrupt sources
//SEI(); //re-enable interrupts
//all peripherals are now initialized
//***** DELAY OF 1 mSEC (appx.) *******
void delay_ms(int miliSec) //for 1 Mhz crystal
int i,j;
for(i=0;i<miliSec;i++)
for(j=0;j<100;j++)
asm("nop");
asm("nop");
//************************ main ***************************
void main(void)
unsigned int counter = COUNTER_MIN;
init_devices();
while(1)
if(increaseButton_PRESSED)
delay_ms(20);
if(increaseButton_OPEN)
while(increaseButton_PRESSED);
delay_ms(20);
if(counter >= COUNTER_MAX)
counter = COUNTER_MAX;
else
counter += KROK;
OCR2 = counter;
else
delay_ms(20);
if(decreaseButton_OPEN) ;
while(decreaseButton_PRESSED);
delay_ms(20);
if(counter <= COUNTER_MIN)
else
counter -= KROK;
OCR2 = counter;
//****************************** END ***************
Andrea
Založen: Sep 07, 2007
PříspěvekZaslal: st prosinec 16 2009, 20:01    Předmět: Citovat
No jestli jsi to psal opravdu ty, tak umíš docela dobře anglicky.
Jak zjišťuješ, jestli ta PWM funguje nebo ne?
mirecc
PříspěvekZaslal: st prosinec 16 2009, 20:49    Předmět: Citovat
Andrea napsal(a):
osciloskop
Andrea
PříspěvekZaslal: st prosinec 16 2009, 21:06    Předmět: Citovat
A jak ten překladač pozná, co máš za procesor? Tam, co jsi ten program opajcoval, mají na začátku #include <iom8v.h>, tak jestli by tam nemělo být něco podobnýho pro AVR GCC.
GeorgeB
Založen: Nov 21, 2005
PříspěvekZaslal: st prosinec 16 2009, 21:40    Předmět: Citovat
Andrea napsal(a):
Tam, co jsi ten program opajcoval, mají ...
Přesně: http://images.robolabz.multiply.multiplycontent.com/attachment/0/SpofCQoKCCwAAFzNnzM1/Stuff%20of%20Dharmanitech.pdf?nmid=279223533 Very Happy
mtajovsky
Založen: Sep 19, 2007
PříspěvekZaslal: st prosinec 16 2009, 22:47    Předmět: Citovat
- máte ten program nějaký "vykuchaný". Zastaví se to na while(1){} a nic se dál nebude dít. V originále je tam "cosi" navíc. Very Happy
- vidím špatně udělanou funkci pro zpožďování. Převážná část kódu bude v těch cyklech for a ne v nop. Takže výsledek silně závisí na tom, jakou optimalizaci překladač provede. Pro zpožďování jsou určené funkce z avr-libc _delay_ms() a _delay_us().
Andrea
PříspěvekZaslal: čt prosinec 17 2009, 8:06    Předmět: Citovat
On tam těch chyb vyrobil víc, ale na funkci PWM by neměli mít vliv.
Atlan
Založen: May 10, 2004
PříspěvekZaslal: čt prosinec 17 2009, 10:29    Předmět: Citovat
Toje tak aj opajcovat treba vediet Very Happy sadnut studovat...
Zmije
Založen: Jun 30, 2005
PříspěvekZaslal: čt prosinec 17 2009, 10:49    Předmět: Citovat
Pokud to překládaš ve WinAVR pomocí GCC, tak naprosto špatně pracuješ s vektory přerušení, na začátek musíš dát kromě #include <avr/io.h> ještě #include <avr/interrupt.h> a obsluhu přerušení potom dát do ISR( TIMER2_COMP_vect ){ //nejaky kod }pokud chceš obsloužit přerušení od c/t2 při shodě, ostatní vektory viz. tabulka.
PS: nezapomeň povolit globální přerušení sei() ;
 Soubor:  INTvektory.jpg
 Velikost:  60.78 kB
 Staženo:  109 krát
Zmije
PříspěvekZaslal: čt prosinec 17 2009, 11:01    Předmět: Citovat
Dodávám, že tabulka platí pro ATmega16, pro ostatní procesory se potřebné informace nachází v datasheetech.
