Založen: Oct 30, 2005 Příspěvky: 3899 Bydliště: VT SLOVAKIA
Zaslal: ne duben 12 2026, 13:00 Předmět:
Nejaké diely pre BEG220K , ale či bude pasovať pre BEG220, neviem. _________________ „Hľadáme nepoznané, spoznávame nehľadané. Strácame to cenné, ceníme si až stratené. Milujeme všetko zradné a zrádzame milované.”
Pozdravuje Vás Martin
Přehled od AI
The Black & Decker BEG220, BEG220K, and BEG220-QS are all variations of the same 900W 125mm compact angle grinder. The core tool (motor, speed, power) is identical across these models. The differences lie in the packaging, accessories, and regional coding.
OBI
OBI
+2
Here is the breakdown of the differences:
1. Black & Decker BEG220 (Base Model)
What it is: The basic angle grinder, usually supplied in a cardboard box with a side handle, guard, and inner/outer disc flange.
Best for: Someone who already has discs and a carrying case.
Zboží.cz
Zboží.cz
2. Black & Decker BEG220-QS (Standard Package)
What it is: This is the standard retail version for the European market ("QS" denotes regional coding for Europe/general export). It is the same 900W tool, featuring a soft-start motor, 3-position handle, and a slide-lock switch.
Package: Usually comes in a branded box with standard accessories (guard, side handle, wrench).
Best for: Standard DIY tasks.
Amazon.com.be
Amazon.com.be
+2
3. Black & Decker BEG220K (Kit Version)
What it is: The "K" suffix traditionally indicates a "Kit" version in Black & Decker naming conventions.
Package: This version usually includes the angle grinder along with a carrying case/toolbox (and sometimes a starter disc or accessories).
Best for: Those who need storage for their tools or a portable kit.
BLACK+DECKER
BLACK+DECKER
+2
(Google překlad):
Přehled od AI
Black & Decker BEG220, BEG220K a BEG220-QS jsou varianty stejné kompaktní úhlové brusky s výkonem 900 W a 125 mm. Základní nástroj (motor, rychlost, výkon) je u všech těchto modelů shodný. Rozdíly spočívají v balení, příslušenství a regionálním kódování.
OBI
OBI
+2
Zde je rozpis rozdílů:
1. Black & Decker BEG220 (základní model)
Co to je: Základní úhlová bruska, obvykle dodávaná v kartonové krabici s boční rukojetí, krytem a vnitřní/vnější přírubou kotouče.
Nejlepší pro: Někoho, kdo již má kotouče a přepravní pouzdro.
Zboží.cz
Zboží.cz
2. Black & Decker BEG220-QS (standardní balení)
Co to je: Toto je standardní maloobchodní verze pro evropský trh („QS“ označuje regionální kódování pro Evropu/obecný export). Jedná se o stejný nářadí s výkonem 900 W, které je vybaveno motorem s pozvolným rozběhem, třípolohovou rukojetí a posuvným aretačním spínačem.
Balení: Obvykle se dodává ve značkové krabici se standardním příslušenstvím (kryt, boční rukojeť, klíč).
Nejlepší pro: Standardní kutilské práce.
Amazon.com.be
Amazon.com.be
+2
3. Black & Decker BEG220K (verze Kit)
Co to je: Přípona „K“ tradičně označuje verzi „Kit“ v konvencích pojmenování Black & Decker.
Balení: Tato verze obvykle obsahuje úhlovou brusku spolu s přepravním kufrem/krabicí s nářadím (a někdy i startovacím diskem nebo příslušenstvím).
Nejlepší pro: Ty, kteří potřebují úložný prostor pro své nářadí nebo přenosnou sadu.
BLACK+DECKER
BLACK+DECKER
+2
_________________ Honza - kokúň
__________________________
Díky. Je tu drobná šance, že pro to občasné drobné domácí pošolichání postačí nový pastorek. Rozsah poškození protikusu nedokážu posoudit.
I s poštovným by to pak vyšlo na 1/3 ceny nové rozbrusky.
Založen: Mar 16, 2005 Příspěvky: 35470 Bydliště: Česká Třebová, JN89FW21
Zaslal: ne duben 12 2026, 21:50 Předmět:
Při dnešních cenách i kvalitě (Black&Decker byla navíc jedna z prvních firem, která samotnou výrobu "outsourcovala" do PRCácka) bych nejpozdějc v momentě zjištění očesanejch zubů hledal nejbližší červenej kontejner nabo SD a rovnou po cestě bych si koupil novou flexu. _________________ Nasliněný prst na svorkovnici domovního rozvaděče: Jó, paninko, máte tam ty Voltíky všecky...
A kutilmile - nelituju tě !!!
Přidal jsem ve své předchozí zprávě fotku protikusu pastorku. Je použitelný?to rnbw: dobrá rada! v polsku lze sehnat za 22 zlotých. _________________ pro mládež a lektory - Hamíkův koutek
Naposledy upravil kulikus dne ne duben 12 2026, 22:10, celkově upraveno 1 krát.
Zaslal: ne duben 12 2026, 22:09 Předmět:
Ne, je dost důkladně VOMLETEJ. Opakuju, tohle je na novou "karbošku" ... _________________ Nasliněný prst na svorkovnici domovního rozvaděče: Jó, paninko, máte tam ty Voltíky všecky...
Mám podobně odrbanou flexu, nechal jsem si spíš jen tak ze srandy na zkoušku vytisknout jen pastorek z nerezi za asi $5 v číně a jede to. Ale přesunul jsem flexu z dílny domů kde ji použiju tak 5x za rok na nějakou drobnost a do dílny koupil novou.
