DrayTek Vigor2110 - dokola sa restartuje
PříspěvekZaslal: čt červenec 11 2024, 18:31    Předmět: DrayTek Vigor2110 - dokola sa restartuje Citovat
Ethernetovy router DrayTek Vigor2110 prestal fungovat - zacne bootovat, ale hned sa restartuje. Elyty som vymenil - boli dobre, takze ziadna zmena. Tak som cez bootloader a TFTP preflashoval firmware - a stale sa to sprava rovnako. Vypis z konzoly:
kód:
ROM VER: 1.0.3
CFG 01
Read`
ROM VER: 1.0.3
CFG 01
Read EEPROMX
 X
 relocate_code start
 relocate code finish
 Go...
 IO_Port_Init!!
Detect existed devices!!Modes: __STDC__ 32-bit mwDWORD==(unsigned long)
mwROUNDALLOC==4 sizeof(mwData)==24 mwDataSize==24
statistics: now collecting on a line basis
============= Memwatch Auto Self Test =============
Normal Free...DETECTED
Double Free...DETECTED
NULL Free.....DETECTED
Wild Free.....DETECTED
Underflow.....DETECTED
Overflow......DETECTED
Unfree 1......DETECTED
Unfree 2......DETECTED
ALL TEST OK!
Please be assured that all test buffers have freed.
Slab kmalloc range:     [0x8088B838:0x80F8C837](size=7344127 bytes)
Linear malloc range:    [0x818A2C90:0x81EFF000](size=6669168 bytes)
 !!! Maxi malloc size =2076655000 (st=628b268, end=81eff000)!!!!
 init cpu_wait to r4k_wait()!!
 trap_init() doneTODO: chip version
 danube_setup() donemips_hpt_frequency:166666667
r4k_offset: 00196e6a(1666666)
Using 166.667 MHz high precision timer.
 c0_hpt_timer_init()..count=1803382456.
 time_init()...
 dma_init() done
 init_IRQ() partial done
 skb_init() doneCPU revision is: 00019641
 cpu_report() donePrimary instruction cache 16kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 16kB, 4-way, linesize 32 bytes.
 cache_init() donePCI: Probing PCI hardwar~
ROM VER: 1.0.3
CFG 01
Toto sa opakuje dokola, vzdy to skonci presne na "PCI hardwar". PCI zariadenie tam ziadne nie je - je to verzia bez wifi. Je tam len CPU, RAM, flash a switch. Switch nie je odpaleny, vsetky porty funguju (po pripojeni kabla sa rozsvieti prislusna LED).
Napajanie na osciloskope OK. Skusal som aj pripojit 3,3V z lab. zdroja - bez zmeny.
Ostava uz asi len vadna RAM alebo samotny CPU? Je tam vraj VSC7501, ale je na nom nalepeny chadic.
 Velikost:  254.1 kB
 Zobrazeno:  73 krát
Mahoney
Založen: Oct 26, 2019
PříspěvekZaslal: pá červenec 12 2024, 8:12    Předmět: Citovat
Pravděpodobně vyhřátý. Jestli si s tím chceš hrát, místo originálního firmware naflashuj MemTest pro MIPS architekturu a nech to běžet minimálně 24 hodin (pokud poběží).
PříspěvekZaslal: pá listopad 28 2025, 22:48    Předmět: Citovat
Objavil som tento odlozeny router, zapojil a normalne fungoval Shocked
Mahoney
PříspěvekZaslal: so listopad 29 2025, 8:26    Předmět: Citovat
Dej mu pár dnů, jestli se uhřeje, tak nejspíš cínový mor a reflow.
PříspěvekZaslal: so listopad 29 2025, 9:48    Předmět: Citovat
Mal som v rukach aj dalsie kusy, mrtve kvoli elytom. Po vymene to vzdy ozilo, ale u viacerych som si vsimol problemy s LED - neblikali normalne (len ACT v intervale 1Hz), ale postupne sa vsetky rozsvietili a nasledne zhasinali (tiez v intervale 1Hz). Ovladane su cez dve 74HC595.
Mam podozrenie na procesor v BGA. Chladic na nom je nalepeny "natvrdo" a jednym koncom aj na RAM. Takze pri zmene teploty to vytvara pnutie az niektory spoj povoli. Signaly pre ovladanie LED to asi postihne ako prve.
Mahoney
PříspěvekZaslal: so listopad 29 2025, 12:00    Předmět: Citovat
'natvrdo' znamená keramickou pastou? Na RAM je ta pasta taky?
Jestli je ta RAM tvrdou pastou, tak možná nadfrézovat ten spoj (dremelkou, nechat spoj na RAM a zajet do hliníku nad tím, ale bude to asi práce, že mě nenapadá žádné slušné slovo...)
Naposledy upravil Mahoney dne so listopad 29 2025, 12:04, celkově upraveno 1 krát.
PříspěvekZaslal: so listopad 29 2025, 12:03    Předmět: Citovat
Na celej spodnej ploche chladica je nejaka obojstranna paska, co stvrdla na kamen. Roh chladica je tym padom prilepeny ciastocne na RAM.
Naposledy upravil rnbw dne so listopad 29 2025, 12:07, celkově upraveno 1 krát.
Mahoney
PříspěvekZaslal: so listopad 29 2025, 12:05    Předmět: Citovat
Zkusil bych tu frézku...
Čas potřebný ke zpracování stránky 0.61 sekund
