AMD Athlon 64 X2 5000+ sa prehrieva - delid?
PříspěvekZaslal: st srpen 13 2025, 18:00    Předmět: Citovat
Chcem ten heatspreader nalepit naspat (kedze tam je silikon, tak tiez silikonom), aby som mohol bez uprav a obav nasadit povodny chladic.
PříspěvekZaslal: pá srpen 15 2025, 15:22    Předmět: Citovat
Ziletku nemam a lamaci noz je trochu hruby - do medzery vojde len kusok ostria. Ale da sa to.
Najprv som to dokola obrezal spickou. Potom do vzniknutej medzery vlozil noz po celej dlzke jednej strany a naklepal ho tam kladivom. To som opakoval pre vsetky 4 strany a nakoniec sa to uvolnilo.
Pasta bola tvrda, tak som ju odstranil a dal tam MX-2 (mam tu celu tubu, tak to davam vsade). Na povodny cierny silikon som naniesol tenku vrstvu noveho (obycajny sanitarny), priplacol naspat. Hned som to osadil do dosky, dal pastu a nasadil chladic, nech to ma pri tuhnuti spravny pritlak.
Idle:
kód:
atk0110-acpi-0
Adapter: ACPI interface
Vcore Voltage:     1.17 V  (min =  +0.85 V, max =  +1.60 V)
 +3.3 Voltage:     3.38 V  (min =  +2.97 V, max =  +3.63 V)
 +5 Voltage:       5.05 V  (min =  +4.50 V, max =  +5.50 V)
 +12 Voltage:     12.53 V  (min = +10.20 V, max = +13.80 V)
CPU FAN Speed:   2051 RPM  (min =  800 RPM, max = 7200 RPM)
CPU Temperature:  +31.0°C  (high = +60.0°C, crit = +95.0°C)
MB Temperature:   +37.0°C  (high = +45.0°C, crit = +95.0°C)
k8temp-pci-00c3
Adapter: PCI adapter
Core0 Temp:   +30.0°C
Core0 Temp:   +27.0°C
Core1 Temp:   +37.0°C
Core1 Temp:   +31.0°C
Zatazene obe jadra - po 10 minutach:
kód:
atk0110-acpi-0
Vcore Voltage:     1.40 V  (min =  +0.85 V, max =  +1.60 V)
 +3.3 Voltage:     3.35 V  (min =  +2.97 V, max =  +3.63 V)
 +12 Voltage:     12.34 V  (min = +10.20 V, max = +13.80 V)
CPU FAN Speed:   3125 RPM  (min =  800 RPM, max = 7200 RPM)
CPU Temperature:  +72.0°C  (high = +60.0°C, crit = +95.0°C)
MB Temperature:   +45.0°C  (high = +45.0°C, crit = +95.0°C)
k8temp-pci-00c3
Core0 Temp:   +67.0°C
Core0 Temp:   +66.0°C
Core1 Temp:   +65.0°C
Core1 Temp:   +67.0°C
Procesor opraveny Very Happy
asdf
Založen: Oct 06, 2022
PříspěvekZaslal: pá srpen 15 2025, 17:03    Předmět: Citovat
Hmm, dobrý. Ten můj bez pasty má 85 st.C. při zátěži. Ale zase tam nemá co ztvrdnout, tak to asi nechám.
