Aplikace na kreslení kabeláže.
dzinzlahve
Zablokován
Založen: Dec 07, 2022
PříspěvekZaslal: út prosinec 13 2022, 11:34    Předmět: Aplikace na kreslení kabeláže. Citovat
Čau, začínám s touto "aplikací - https://github.com/formatc1702/WireViz/issues/174 - a kód mi v ní fungoval, dokud jsem nechtěl začít to dělit podle kabelů.
kód:
connectors:
  X1:
    type: TV06RW-11-35S
    subtype: female
    pincount: 79
    pins: [1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,72,73,74,75,76,77,78,79]
    pinlabels: [ 5SENSqE_P_1, SENSE_N_1, SENSE_P_2, SENSE_N_2, SENSE_P_3, SENSE_N_3, SENSE_P_4,SENSE_N_4, SENSE_P_5, SENSE_N_5, SENSE_P_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6]
  X2:
    type: TV06RW-11-35S
    subtype: female
    pincount: 79
    pinlabels: [ SENSxE_P_1, SENSE_N_1, SENSE_P_2, SENSE_N_2, SENSE_P_3, SENSE_N_3, SENSE_P_4,SENSE_N_4, SENSE_P_5, SENSE_N_5, SENSE_P_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6, SENSE_N_6]
cables:
  W1:
    gauge: 0.25 mm2
    colors: [WH, BN, GN, YE]
    length: 3350
    color_code: DIN
    wirecount: 71
    shield: true
  GSC-01-86019-00 DVI0:
    wirecount: 8
    length: 3350
    shield: true
    colors: [BN, WH, OG, WH, GN, WH, BU]
connections:
    - X1: [3,4,5,6,7,8,9,10]
    - GSC-01-86019-00 DVI0: [3,4,5,6,7,8,9,10]
    - X2: [3,4,5,6,7,8,9,10]
    - X1: [1,2,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,31,32,33,34,35,36,37,38,39,40,41,42,44,45,47,48,53,54,55,56,57,58,59,60,70,75,76,77,78,79]
    - W1: [1,2,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,31,32,33,34,35,36,37,38,39,40,41,42,44,45,47,48,53,54,55,56,57,58,59,60,70,75,76,77,78,79]
    - X2: [1,2,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,31,32,33,34,35,36,37,38,39,40,41,42,44,45,47,48,53,54,55,56,57,58,59,60,70,75,76,77,78,79]
A je problém, že ta aplikace spadne, nevygeneruje nový obrázek, a ani nemá nějaký "error log" abych věděl, co je za problém. Confused
Nějaké tipy?
