C:\Program Files\Raisonance\Ride\bin>STM8_pgm.exe TSTM8S003K3 Ddump.bin
STM8_pgm: software for programming STM8 devices using an RLink as master.
Copyright Raisonance 2007-2024.
(0) Selecting target: STM8S003K3... OK
(0) (0) Connecting to RLink... OK
Connecting to target STM8... OK
Device Die ID is 0x67671003
Device Unique ID is 0x........................
Dumping Flash contents to file dump.bin ...
!!! Error 203: Unable to read data because Read-Out Protection is active in Option Bytes.
Only Full-Chip Erase can remove protection.
Je to na doske GeekTeches DC-300, predava sa aj ako "Adjustable DC-DC Step Down Power Supply Module With LCD" alebo "MP2307 DC-DC Step-Down Module With LED Display". Kupim LMC555 a vyskusam to.
Založen: Aug 02, 2009 Příspěvky: 1587 Bydliště: Praha
Zaslal: út červen 10 2025, 21:12 Předmět:
Jo tyhle power glitche by mely fungovat i na nake STM32 a treba GALy, v praxi jsem to jeste nezkousel. Obecne to chce presne nacasovat zpozdeni pulsu po resetu a dostatecne uzkou sirku, aby se to trefilo akorat do cteni toho protection bitu a nesestrelil to este brownout...
